Date: 21-04-26  Time: 13:43 pm
Author Topic: Fz1 indicator tip  (Read 2007 times)
stevierst
Fz1 indicator tip
« on: 02 May 2013, 12:58:22 pm »
Just bought a set of led indys for my pride and joy as the originals were huge.
Only problem is that for the fz1s you need spacers to stop the new Indy from rattling around in the fairing slot, this costs a fiver or more. :-[
The old indicators are rubber mounted with a plastic 'clip' to hold them in.
This clip is almost the same shape as the fairing slot. To centralize the new Indy in the fairing, this clip is spot on. All I did was file off a couple of mm from each  end of the tabs, and fit it in the rear of the fairing mounting hole so the raised portion was located inside the slot.
Just fit the new indys in, et voilla! Indicator spacers for free! They'll even fit back in the old indicators should you wish to refit them!
jimbowats
Re: Fz1 indicator tip
« Reply #1 on: 02 May 2013, 08:09:45 pm »
They look great! Any tips on how to remove the oem indicators? I've got fairing lowers and they won't fit through the hole( was gonna take fairing off for a spring clean!) :)
stevierst
« Reply #2 on: 02 May 2013, 08:29:30 pm »
I've not worked on one before, and I've no idea how the lowers attach to the fairing. I did most of the work without taking any panels off, apart from the left hand insert had to be removed as there is a fusebox for my heated grips on the inner nearside.
Im sure that if the indicators are the same as mine, they would be able to be modded the same.
Sent from my AT300 using Tapatalk 2
