Date: 25-05-26  Time: 19:56 pm
Author Topic: do you think my oxford grips have packed up?  (Read 2974 times)
devilsyam
« on: 16 April 2013, 08:31:39 pm »
my oxford grips been working fine but this morning turned them on and the first heat light just flashes wont go up in heat setting either do you think the controllers is kaput??
ghostbiker
Re: do you think my oxford grips have packed up?
« Reply #1 on: 16 April 2013, 09:18:45 pm »
Try increased revs a little then turn them on.
Mine used to flash if it decided it wanted more current before turning on.
smegfish1
« Reply #2 on: 16 April 2013, 09:45:15 pm »
I had the same sort of thing, turned out to be the battery.
b1k3rdude
« Reply #3 on: 16 April 2013, 10:45:50 pm »
If u have the digital controller version, those controllers are very picky about voltage, anything below 11-12v and they can cut out. Also said controllers have a habit of dying.
AdieR
« Reply #4 on: 17 April 2013, 10:05:44 am »
Do you only get the problem at idle, or does it happen at higher revs too?
I get the same with my Oxfords at idle (rpm too low for alternator to start charging), and goes back to normal once engine speed rises.
keithfzs1000
« Reply #5 on: 17 April 2013, 06:29:53 pm »
you will probably find that the voltage of the battery is low
devilsyam
« Reply #6 on: 17 April 2013, 10:15:52 pm »
na no difference when running turn on goes right to 40% but wont go up or down grips get warm so suspect the controller now
keithfzs1000
« Reply #7 on: 18 April 2013, 09:48:54 am »
ahh tis now a different problem as the blue light deffo flashes when battery voltage is less than desired however if it goes up  to 40 then sticks you are correct sir the controler is shall we was fooked  :'( however search flea bay as they do come up as individual items without having to buy the whole kit and caboodle
tomjimtom
« Reply #8 on: 18 April 2013, 10:42:17 am »
Mine did this, a quick email to oxford and sent the kit off for inspection (no receipt) and they said yup, switch is gone, here's a new one.
Worth a try :)
