Date:
25-05-26
Time:
19:56 pm
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
fazer 1000 caliper seals 04
« previous
next »
Print
Pages: [
Author
Topic: fazer 1000 caliper seals 04 (Read 3690 times)
bobdog
Weekend Warrior
on:
10 April 2013, 11:56:56 pm »
the front brake calipers are binding slightly on my fazer, gonna try and give them a clean, if not its new seals time, how much for oem seals, anybody used aftermarket seals? any info appreciated thanks.
Logged
dickturpin
Naughty Corner
GP Hero
Re: fazer 1000 caliper seals 04
Reply #1 on:
11 April 2013, 09:07:03 am »
Fleabay is your friend here....about twenty quid i think for genuine seals . Lots.of users on here say use genuine...they fit !
Logged
fazer390
Naughty Corner
WSB Pack Hound
Reply #2 on:
11 April 2013, 11:48:15 am »
Hi Bobdod... I find it's good practice to keep an eye on these Fazer/R1 brakes as they do get a bit crabby; causing them to stick and bind occasionally.
I remove my calipers every so often, remove the pads and clean the pistons in situ with WD40 & a pain brush.
I hope this helps...
Logged
kebab19
GP Hero
Reply #3 on:
11 April 2013, 03:38:11 pm »
Advice for the 600 in the thread below but front calipers are the same
http://foc-u.co.uk/index.php/topic,6995.0.html
I believe genuine Yam seals are considerably more than £20, unless they've radically changed their pricing! More like £20 a seal...
Although pattern seals are indeed often poor & ill fitting, I've gone with Nikone seals in the past with good effect.
Logged
bobdog
Weekend Warrior
Reply #4 on:
11 April 2013, 04:34:40 pm »
just priced for both caliper seals from fowlers including vat. £133.77
thats just for the piston seals. its give them a clean time then aftermarkets look like the way.
Logged
VNA - BMW Wank
GP Hero
Reply #5 on:
12 April 2013, 06:51:42 pm »
Mines a 2004 model.
Every year I remove the pads, push the pistons out a touch and thoroughly clean using brake cleaner (I don't fancy using WD40).
Once I've got em all nice and clean, I give the pistons a smear of Red Rubber Grease and stick the pads in. Give the brake fluid a wee bleed and she stops again like new. And I've still got the rubber hoses fitted.
Don't spend the money on the seals unless they really are focced.
Logged
bobdog
Weekend Warrior
Reply #6 on:
12 April 2013, 09:01:13 pm »
ive no intension changing them unless i have to, the bikes been sorn for a while before i got it so im hoping a good clean will do the job
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
