Date: 07-05-26  Time: 08:52 am
Author Topic: vibrators  (Read 6103 times)
Noj
Re: vibrators
« Reply #25 on: 03 April 2013, 11:57:20 pm »
Motorcycling is not likely caused or make is worse by the frequency and strength that causes are not found on motorcycles (in general), however there are a few that are more agricultural than others. I don't want to cause an offence so I won't mention them.
The throttle rest works well to prevent over gripping and causing pain in hand, this is often referred to as 'white knuckle riding'. Softening your grip when riding or good maintenance of the cables can help the symptoms, I got my rest at Buster's did one that was much better quality and ergonomic.
White finger is nerve damage and is most likely to be from kango's, thumpers and such like and not skill saws, mind you it depends what you use as a blade and how you use it?
