Date: 03-05-26  Time: 15:47 pm
Author Topic: oops - foccing bolts.  (Read 3249 times)
Lazarus
« on: 09 February 2013, 03:48:53 pm »
Putting bits of the bike back together today - was going great guns until I got to the last piece (front fender)
Turns out I have 4 holes to fill but on 2 bolts remaining to do it with.
Need to gut the garage to make sure they arent lying around but I did have a box that I kept all the bolts together in
Makes me think that I might have used the bolts in the wrong place.
On the rear hugger, are these the right bolts to use ?
Additionally, when I was putting the exhaust back on, couldnt help noticing this little fella:
Namely the little black "thingumy" to the right of the heel plate.
What exactly is this - ive noticed that this is pretty loose and does it need to be "tight"
Thanks
Re: oops - foccing bolts.
« Reply #1 on: 09 February 2013, 04:00:53 pm »
Do you ever ride your bike outdoors, it looks extremely clean?  :lol
« Reply #2 on: 09 February 2013, 04:57:24 pm »
Rear Brake light switch and it usually is a bit on the loose side.
Lazarus
« Reply #3 on: 09 February 2013, 06:14:13 pm »
yep - but spent the winter cleaning it up...... :D
Lazarus
« Reply #4 on: 09 February 2013, 06:15:01 pm »
cheers unfazed - already checked the rear brakes and the light definately on - one less thing to worry about.
« Reply #5 on: 09 February 2013, 06:52:53 pm »
The Hugger/ Brake hose mounting bolts are usually 8mm heads and yours appear to be 10mm heads. They are longer than the mudguard bolts
Make sure the bolts for the mudguard are the correct length (around 12mm) and the special shouldered washers are in place.
The shouldered washers prevent overtightening and cracking the mudguard.
If bolts are to long and you try tightening them up you are liable to break off the frork leg mounting.
