Date: 03-05-26  Time: 19:59 pm
Author Topic: Gearbox "Shunt"  (Read 8944 times)
alexanderfitu
Re: Gearbox "Shunt"
« Reply #25 on: 06 February 2013, 10:51:58 am »
lol you scared me there for a second.
It does help, Last weekend I gave mine a nice wash and covering with ACF 50. I highly reccomend diluted muck off on a spray bottle! :)
Re: Gearbox "Shunt"
« Reply #26 on: 06 February 2013, 11:48:24 am »
It's all a bit pointless 'cos they're still gritting the roads around my way, so as soon as it rains it'll be covered in shite again.
alexanderfitu
Re: Gearbox "Shunt"
« Reply #27 on: 06 February 2013, 12:02:40 pm »
True, thats where the ACF50 comes in, all the crap sits on this layer of oil, so when you go to clean it again, it nice and shiny and not corroded :)
JoeRock
Re: Gearbox "Shunt"
« Reply #28 on: 07 February 2013, 01:19:24 am »
If the chains adjusted correctly, only two things I can think of:
Check the rear wheel doesn't move at all (as in from side to side, or front to back physically). Basically that the bearings are fine, and the spindle is done up properly with the adjusters both the same.
Check the rod the front sprocket nut bolts onto, and make sure there's no play in it at all.
Andy FZS
Re: Gearbox "Shunt"
« Reply #29 on: 07 February 2013, 07:22:25 am »
Mine was rough at tick over and slow speed until I balanced the carbs and this made things a lot smoother, have you checked yours recently?  It could have been getting worse for a while but you've only just noticed it. Good luck.
Andy
Sent from my GT-N8010 using Tapatalk 2
alexanderfitu
Re: Gearbox "Shunt"
« Reply #30 on: 07 February 2013, 08:57:04 am »
Mine isnt rough on tickover, its pretty stable, but I have never checked the carb balancing.
It could be that, but I suspect my clutch cable is pretty worn, so Im going to change that first and see if its gets any better. If not then I will get the carbtune out :)
alexanderfitu
Re: Gearbox "Shunt"
« Reply #31 on: 07 February 2013, 08:58:01 am »
No play in the rear wheel bearings or swingarm bearins, all bolts done up correctly :)
I havent checked for any lateral play in the output shaft, so will check that soon. Thanks.
Re: Gearbox "Shunt"
« Reply #32 on: 08 February 2013, 12:40:49 pm »
I've just been out on the bike and before i put it away i had it up on the centre stand and rocked the rear wheel back & forth, and the play in 1st and 2nd gear was 1cm.
alexanderfitu
Re: Gearbox "Shunt"
« Reply #33 on: 08 February 2013, 12:43:14 pm »
1cm , ok so pretty close to mine, which is probably about 2 cm.
Re: Gearbox "Shunt"
« Reply #34 on: 08 February 2013, 12:48:38 pm »
Well, sort of, in a "not really" kind of way!
That's quite a difference as far as play is concerned, although i have no idea what the limits are supposed to be?
alexanderfitu
Re: Gearbox "Shunt"
« Reply #35 on: 08 February 2013, 12:50:57 pm »
hmm true
meh, duno whats up with it!
Re: Gearbox "Shunt"
« Reply #36 on: 08 February 2013, 01:25:20 pm »
Right, i've just been reading a different forum about this issue, and one fella checked 3 bikes for play and they were between one inch, and one and a half inches.
So, on that evidence alone i would pretend that we never had this conversation, and everything is present and correct, because both our bikes have less than an inch of play which sounds good enough to me.
He was checking a Blackbird and 2 x FZR1000's i think?
alexanderfitu
Re: Gearbox "Shunt"
« Reply #37 on: 08 February 2013, 01:55:10 pm »
I think that its normal as well and we are all really paranoid.
I just went out on my XJ600 (1991) as the fazer is missing its broken bits from the fall, and there was no drivetrain shunt on the xj, although the clutch does drag badly on that.
I would say its a characteristic on the bike, and that balancing the carbs would help tremendously, as would checking all the engine mount bolts etc.
All those are things I havent done yet :)
Re: Gearbox "Shunt"
« Reply #38 on: 08 February 2013, 02:11:23 pm »
I had my carbs balanced a few months back, it makes a huge difference at low speed, my bike was very jittery before having them done, although i was told one carb was quite a way out for some reason?
alexanderfitu
Re: Gearbox "Shunt"
« Reply #39 on: 08 February 2013, 02:15:51 pm »
That will be next step then. Have to save up for a vacuum gauge! :(
Sent from my GT-N7000 using Tapatalk 2
