Date: 07-05-26  Time: 14:20 pm
Author Topic: Really quick question about carb needle clip settings?  (Read 2440 times)
reillypadraig
« on: 12 January 2013, 09:27:40 am »
What slot is the clip supposed to be in? I know someone told me slot 3 out of 5 but is that from the top or the bottom of the needle?
Re: Really quick question about carb needle clip settings?
« Reply #1 on: 12 January 2013, 09:31:59 am »
Well if there are 5 slots and it should in slot 3, I guess that would make it the centre one :rollin
reillypadraig
« Reply #2 on: 12 January 2013, 09:40:06 am »
Lol, I left a lot out of that, was ment to say I'm adjusting the needles because I'm lacking on quarter throttle, so was going to adjust the needles, they are already on 3 so should I just move the clip down 1 setting?
« Reply #3 on: 12 January 2013, 10:47:21 am »
Moving the clip down will raise the needle and give the bike a richer mixture.
But if this is still that set of carbs that looked as if they'd spent a year in the sea, I'd give up on them and find a newer set from a breakers. If a passageway is blocked or a jet has widened through corrosion or an adjuster has seized, moving the needles about isn't likely to correct things.
« Reply #4 on: 12 January 2013, 11:03:23 am »
Dump them a buy a second hand set
reillypadraig
« Reply #5 on: 12 January 2013, 11:13:53 am »
I think that's my only option now, had a good look, they are just abit beyond repair now, idle screws ain't movin,
Carb hunt is now on.... :'(
« Reply #6 on: 12 January 2013, 02:21:47 pm »
yes +1 for replacement carbs,be waste of money getting them sonic cleaned ,good luck with your search  :)
