Date: 25-04-26  Time: 22:55 pm
Author Topic: Ignition Barrel - 5LV  (Read 2710 times)
camroc5
« on: 07 January 2013, 10:56:26 pm »
Hi all , I seem to have run into a problem.
I have a 2004 FZS1000 (5LV) and the Ignition Barrel is broken. The key is loose , comes out when turned on , power flickers, bike cuts out and is unsafe.
I ordered a replacement from a 2003-5LV and it does not fit.
The orignial has 2 block connecters , one with 2 wires the other with 5 wires.
The Replacement has one with 2 wires , but the other block only has 3 wires.
I know that the 1C2 model is different and it has the 3 wire block connecter but does anyone know if there is two versions of the 5LV model.
I was thinking I may have been sold the wrong part but they where sure its a 2003-5LV , then I thought that even though mine is reg'ed 2004 it could be a 2002 model.
Can I use any other Ignition Barrel , or am i stuck finding a 2001-2002 model.
or
Does anyone know if I can still 'Wire' the two connectors block together?.
Thanks,
Camroc
The Male Whale
Re: Ignition Barrel - 5LV
« Reply #1 on: 07 January 2013, 11:10:44 pm »
I can't answer the question but suspect the one you have got is off the earlier models with switchable headlights and yours is permanent headlights???
Not sure if that helps.....
Whale
camroc5
« Reply #2 on: 08 January 2013, 12:02:44 am »
My bike is with the switchable headlights on the Right-Hand side.
Mode 1 is front-side lights and rear lights , mode 2 is full front and rear.
Maybe thats the extra two wires are for.
Do you know when they changed the model to always on lights?
solorider
« Reply #3 on: 08 January 2013, 04:12:30 am »
the 2003 to 2005 had the same switch http://www.yamahamotorcyclespares.co.uk/spares/partImage.asp?GPN=Z%3AQ%5B%3D7%3A567555&uid=0 it is possible that the lock you bought was from a 2002 model registered in 2003
sirgalahad3
« Reply #4 on: 08 January 2013, 04:59:24 pm »
The difference is indeed due to the hard wired lights on in the 03+ on bikes. If a bike/car is right on a change of spec like this it is sods law you will get the wrong part..giving the reg is no help as the bike could be a late registered early one..
You need to swop your new lock!!
ghostbiker
« Reply #5 on: 08 January 2013, 05:27:41 pm »
As above, I had same problem early this year. It is as said pre light and post light switch.
It's one of the few minor changes over the years.
devilsyam
« Reply #6 on: 08 January 2013, 07:55:53 pm »
funny that i have a similar issue mines a 02 i got one of eblag but was for a non headlight version and was not as discribed so got me money back so after a cheap early version
camroc5
« Reply #7 on: 24 January 2013, 07:09:29 pm »
Ok then , I just messed up bad  :'(
I ordered the part from the above link , and its wrong. I didnt look at my VIN number correctly before i ordered.
So..... just to be sure, can someone confirm.
I have a Fazer 1000 with VIN number JYARN061.........
It has the headlight swith on the right hand side.
Does this mean its a 2001-2002 version of the bike?
Does it matter thats its an EX-UP version , or are they all?
I can order the part for the 'RN061' version , but I have been looking around the interwebs and Ebay , and some pictures for the 2001-02 model only show 1 connection box (with 4 wires).
The broken part on my bike has 2 cables under the petrol tank , one has 2 wires that power the bike when connected , the other has 5 wires. I have not yet traced these , to see what each does. I need to wait till weekend to strip the wires. I am gonna try and hardwire a switch of some kind untill I can be sure Im getting the correct part.
sirgalahad3
« Reply #8 on: 25 January 2013, 03:33:44 pm »
Not sure about vin numbers but if your bike has a headlight switch its one of the earlier ones,probably pre 03.
All Fazers are exup versions.
Some ebay sites use a common pic of a part whatever it is.
May I suggest you talk to a supplier and discuss with him exactly what you want as ebay is sure to go wrong under situations like this...
May I also suggest you dont strip/bodge wires as that will also wrong!
