Date: 26-03-26  Time: 06:48 am
Author Topic: 1-2 gear change  (Read 14825 times)
Re: 1-2 gear change
« Reply #25 on: 30 April 2013, 07:14:57 am »
After the few comments yesterday i rode home from work and in contrast to what people are saying on here my gear changing from 1st to 2nd was seamless and very smooth, as in virtually all of the gears.
The only time it clunks is neutral to 1st, but even that's not as bad as it used to be.  :D
riz
Re: 1-2 gear change
« Reply #26 on: 30 April 2013, 12:45:14 pm »
It would also help if you removed the sprocket cover and cleaned the chain lube/road gunk out of the clutch push mechanism. I use brake cleaner for this and then once clean relube with a good quality spray grease.... This will make a big difference to the clutch.
As i doubt the previous owner gave it much tlc i thought i'd do this today, oh my!!!!, i wish i'd taken a piccie, it was FULL of old chain oil/grit etc, so currently cleaning/relubeing now.
One question in all the gunk i found a 1 1/2" cylindrical white nylon bush, i'm guessing this is mean to go onto the gear selector rod? (pretty sure it was just floating in the gunk)
EDIT, Found some pictures and it does.
Next door is a childminder so will have to wait untillthe school run to see if its any different now (i'm sure the power/weight ratio will have improved!!)
riz
Re: 1-2 gear change
« Reply #27 on: 30 April 2013, 04:34:13 pm »
Feels better 1-2, although to be fair it never felt that bad. Now i've got the selector too high, is there an 'official' way of refitting, or just a trial and error job?
Chris
Re: 1-2 gear change
« Reply #28 on: 30 April 2013, 04:40:00 pm »
think it's a bit of trial and error to be honest.
Chris
gassitt
Re: 1-2 gear change
« Reply #29 on: 30 April 2013, 08:10:45 pm »
line up the punch mark on the end of the shaft with the slot in the gear change arm
Then use the rod adjuster to set it where you want it
Simples
riz
Re: 1-2 gear change
« Reply #30 on: 30 April 2013, 08:16:13 pm »
Cheers gassitt, i took a 10mm spanner out with me for a small ride and kinda winged it, feels ok, but will look in the morning to get it right.  :)
Re: 1-2 gear change
« Reply #31 on: 30 April 2013, 08:32:43 pm »
If the lever's a bit high, you need to get a pair of these.......
riz
Re: 1-2 gear change
« Reply #32 on: 30 April 2013, 08:35:13 pm »
They look great and i would ask where you bought yours from but i'd worry if they came undone i'd get the laces in the chain.
Chris
Re: 1-2 gear change
« Reply #33 on: 30 April 2013, 11:30:38 pm »
 :rollin :rollin :rollin
Where can I get a pair of those beauts??
Chris
