Date: 28-04-26  Time: 09:13 am
Author Topic: Anyone changed the pegs -Gen 1  (Read 3913 times)
JayB
« on: 22 October 2012, 12:37:20 pm »
Been thinking of putting some solid pegs on the bike, mainly as it is what I am used to and it will give more feel and also a bit more legroom to boot, but also the rubbers are a bit tatty on mine and I will be removing the back pegs for the time being too.
Anyone know if R1 footpegs go on OK or if they need spacing?
Falcon 269
Re: Anyone changed the pegs -Gen 1
« Reply #1 on: 22 October 2012, 02:18:46 pm »
If you mean complete R1 footrest assembly, no, they won't fit.
I fitted Oberon pegs on mine but I can't recall if they were fixed or hinged.  I've since changed to LSL rearsets. :)
I do recall that the Oberon pegs felt masses better than the stock rubber-topped jobbies.  Also, to my surprise, they seemed to transit fewer vibes.  Odd.
fazer390
« Reply #2 on: 22 October 2012, 02:29:18 pm »
I have some aftermarket ones from Ebay. I think I paid less than £30 for 2 sets. They look just like Oberon foot pegs, but a lot cheaper...
I drilled out the old pivot pin to remove old foot peg, then fit the new foot peg replacing the drilled out pivot pin with a Nyloc nut 7 bolt. Piece of cake  ;)
Tmation
« Reply #3 on: 22 October 2012, 02:48:04 pm »
I have the oberon touring pegs on mine, as above drilled the end of the old fixing then fitted the new pegs using the original spring. Oberon supplied new nyloc nuts, bolts and washers. 10 mins work maximum
JayB
Re: Anyone changed the pegs - Gen 1
« Reply #4 on: 22 October 2012, 03:08:52 pm »
I just meant the actual peg, not the hanger, I realised that they would not interchange. Yamaha didn't obviously realise metals would become precious in the future when they set those moulds up  :lol
Seen some cheapo ally ones with springs, fixings the lot for about £7-8 on the bay.
I assume from your replies the originals are fixed in place? Usually they have 'c' clips or split pins through.
devilsyam
« Reply #5 on: 22 October 2012, 03:21:11 pm »
buell pegs good mod lowers by inch
JayB
« Reply #6 on: 22 October 2012, 03:55:59 pm »
Hmm, cool, any chance of touching down?
these are what I've seen, cheaper than dirty used ones from breakers too.
http://www.ebay.co.uk/itm/310358329403?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
ghostbiker
« Reply #7 on: 22 October 2012, 11:06:03 pm »
I had some cheap ones of eBay fitted and they felt fine but lost the black colour in a few months.
Simple to drill the rivet out and swap over.
I touch down the oe pegs now and then so tried some angled alloy ones that I didn't ground.
But changed back to oe ones now as I use the pegs to let me know I'm pushing to hard. With the angled ones it got twitchy before the touched.
But very easy to swap and play around.
phil on a fazer
« Reply #8 on: 23 October 2012, 01:54:01 pm »
really? which buell ones fit?
JayB
« Reply #9 on: 23 October 2012, 03:21:00 pm »
I just meant the actual peg, not the hanger, I realised that they would not interchange. Yamaha didn't obviously realise metals would become precious in the future when they set those moulds up  :lol   OH NO, I meant the frame covers.
karlo
« Reply #10 on: 23 October 2012, 05:02:59 pm »
Buell Ulysses N0006.1AD
http://www.vfrdiscussion.com/forum/index.php/topic/18932-buell-footpegs-modification/
I did the mod on my last bike (CBR)
I had some spacers made to convert the pegs 11mm hole to fit the 8mm pin of the CBR.
karlo
fireblake
« Reply #12 on: 23 October 2012, 07:00:58 pm »
I'd like to change mine but am worried about any extra vibes which I definitely don't want. Also I find that fixed pegs catch on the top of my boots causing drama and hilarity as i fall over.
devilsyam
« Reply #13 on: 23 October 2012, 07:03:44 pm »
