Date: 08-05-26  Time: 23:10 pm
Author Topic: Anyone tried a R6 shock on a 600?  (Read 9963 times)
kebab19
Re: Anyone tried a R6 shock on a 600?
« Reply #25 on: 27 October 2012, 12:34:07 pm »
The 2010 onwards R6 shock is from a bike weighing about 170kg dry
It fits (and works well) on the Fazer 1000 which is 208kg dry
From what I can see, this mod for the 1000 largely works due to the retention of the original suspension linkages.
So if the R6 shock fits the Fazer 600 and uses the 600's suspension linkages, it may well suit a bike that weighs somewhere in between the two (189kg dry?), particularly with the spring preload backed off near minimum.
Theory is all very well,  we've now reached the point where someone needs to fit it. Unfortunately, while I do have an R6 shock and a Fazer 1000, I have no 600 :-)
Bwizz - I take it you intend to fit standard length dog-bones?
bwizz
« Reply #26 on: 27 October 2012, 02:42:23 pm »
Yes I intend using standard dog bones. i'm a short arse so on the thou ,The r6 shock being a bit shorter suits me fine. As you point out theory is one thing!  In the case of fitting to a 600 I'm guessing that the gas compression will need to be nr max to compensate for the weaker spring!  Waiting for the insurance company to sort out damage on the 600 so can't do ow't yet!
