Date: 25-04-26  Time: 01:53 am
Author Topic: clutch question  (Read 13800 times)
solorider
clutch question
« on: 04 October 2011, 10:10:53 pm »
i need to buy some new clutch plates so is it worth buying heavy duty springs or am i better off sticking with a set of genuine springs?
scousy
Re: clutch question
« Reply #1 on: 04 October 2011, 11:39:43 pm »
if it helps i asked the same quetion to the guys at Bike Torque Racing Ltd and they said standard springs are fine , that was with a Surflex clutch kit which is allegedly much better than an OE clutch ?
solorider
Re: clutch question
« Reply #2 on: 05 October 2011, 05:07:16 am »
im going to be hetting a ebc clutch plates,the surflex plates are a bit over my budget at the moment
b1k3rdude
I have just fitted a completly new clutch
« Reply #3 on: 05 October 2011, 04:35:45 pm »
my suggestion, get stock springs (as the pattern springs make the clutch action noticeably heavier) and the other thing I found was the pattern friction plates screwed up the biting point, but this may have been an issue with the thickness of the pattern plates all being 3mm when compared to the oem have a 4 at something like2.5mm and the rest at 3mm etc.
solorider
Re: I have just fitted a completly new clutch
« Reply #4 on: 05 October 2011, 05:31:19 pm »
i would love to get a genuine clitch,but i cannot afford the cost of it at £159.57 plus the cost of the springs.
it is possible that my bike may already have a pattern clutch as the biting point is near the end of the lever travel
b1k3rdude
Re: clutch question
« Reply #5 on: 06 October 2011, 01:22:45 pm »
My previous thou's never needed to the clutch replacing, so can't say for sure. All I can say is with the pattern plates/springs in in the brand new clutch & boss, the cable adjusted to there was virtually no free-play, the biting point was 1.5-2" away from the bar!
solorider
Re: clutch question
« Reply #6 on: 06 October 2011, 04:54:27 pm »
that is how mine is at the moment
mike26
Re: clutch question
« Reply #7 on: 07 October 2011, 07:25:24 am »
STANDARD SPRINGS!!! i have HD clutch springs and now i also have a pretty strong left hand
b1k3rdude
Re: clutch question
« Reply #8 on: 07 October 2011, 10:11:12 am »
Hmmm, you could try the pattern plates with your old springs, as long as the springs aren't shorter than 50mm they can be reused.
