Date:
11-04-26
Time:
13:42 pm
Home
Media
old - Fazer Owners Club - old
cant change gear!!
« previous
next »
Print
Pages: [
Author
Topic: cant change gear!! (Read 1564 times)
freddyboy2404
Cager in Training
cant change gear!!
on:
21 June 2012, 01:15:39 am »
on my way in to work,,, my fz6 would only change up to 2nd gear,, with a bit of coasting got int higher gears,, any ideas??
Logged
The Rocketeer
Naughty Corner
GP Hero
Re: cant change gear!!
Reply #1 on:
21 June 2012, 01:18:41 am »
Clutch pushrod? Chain too tight?
Logged
Tmation
Naughty Corner
GP Hero
Reply #2 on:
21 June 2012, 06:31:57 am »
First thing to do is clean, lubricate and adjust your gear shift mechanism. Then check and adjust your clutch cable and check that the clutch is operating, if it selects 1st and 2nd gear and pulls away properly it should be ok.
Another thing that can break is the detent spring which makes if difficult to select gears, this is also easy to change, normally behind a plate close to the front sprocket.
Have you checked out the link for Hot Poop near the top of the page?
Good luck
Logged
Print
Pages: [
« previous
next »
cant change gear!!
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
