Date: 07-05-26  Time: 17:24 pm
Author Topic: Quite possibly a daft exhaust question?  (Read 7371 times)
69oldskool
« on: 19 June 2012, 06:51:15 pm »
Ok,
    i've decided a louder can is in order, but i'm far too tight to replace the standard one given it's in good shape & i've a long list of other "to do's"
I'm guessing there's some wadding put in there by Mr Yamaha & co.
My question being~ is it possible to remove some of it for a more sporting exhaust note & if so how?
Re: Quite possibly a daft exhaust question?
« Reply #1 on: 19 June 2012, 07:04:55 pm »
I would imagine your back pressure would be affected, and there's no guessing what sound it would make?
rjd1
« Reply #2 on: 19 June 2012, 07:32:48 pm »
years ago before can`s were affordably we used to weld a drill bit to a bit of threaded bar and drill the inard`s out took a while an a bit fidly but worked well and you get all the gain of a free flow if done right
69oldskool
« Reply #3 on: 20 June 2012, 04:20:42 am »
Ok, thanks for the replies folks.
I do have a spare can to experiment with, just trying to get a handle on what exactly's inside.
Jamieg285
« Reply #4 on: 20 June 2012, 08:53:56 am »
Not exactly bike related, or directly relevant, but a few years ago I was a tech inspector for the Legends race cars, which ran the 1200cc engines, with a Micron can.
One race meet we picked up a different exhaust note on one of the cars, so pulled the exhaust apart to compare with a brand new item.  The new one had what I believe to be some form of fibre glass matting, whereas the 'revised' version was packed with wire wool.
The owner, and modifier of this exhaust is also the owner of a well known aftermarket stainless steel exhaust company, so I guess he had some idea of what he was doing...
« Reply #5 on: 20 June 2012, 09:21:31 am »
I've had occasion to open up a couple of OE silencers and found them to have two or three chambers with a number of 1" tubes as interconnectors. I've not dismantled an original Fazer exhaust though, so will be interested to hear what you find.
Other than the one on a little Yamaha 2-stroke I used for a while, the only silencers I've seen that employ a central perforated tube surrounded by an absorbent wadding have been after-market ones.
I suspect that the noise and heat that glass fibre wadding is subjected to causes it to slowly disintegrate and blow out with the exhaust gases anyway.
JZS 600
« Reply #6 on: 20 June 2012, 11:37:27 am »
anyone tried the Fuel brand end cans?
They look pretty neat, seem to have a good write up and are reasonable priced.
Bracechenko
« Reply #7 on: 20 June 2012, 02:04:29 pm »
Got a fuel can on my FZS600 and it provides a great sounds....overrun is fantastic! It's loud enough when you want it to be but you can settle it down so it's not annoying when you just want to ride in a more relaxed manner.....passes the MOT without the baffle each time too!
JZS 600
« Reply #8 on: 20 June 2012, 06:27:36 pm »
Sounds like just the job!
