Date:
21-05-26
Time:
01:11 am
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
ram mount for violetsdaddy
« previous
next »
Print
Pages: [
Author
Topic: ram mount for violetsdaddy (Read 3201 times)
fazer69
CBT Wobbler
on:
07 May 2012, 03:33:53 pm »
just read the ram mount post, i hope these help
Logged
violetsdaddy
DAS Born Again
Re: ram mount for violetsdaddy
Reply #1 on:
07 May 2012, 04:45:25 pm »
Yes, that helps a lot.
I'm looking to do what you've done on the centre yoke nut, how did you do that?
I've discovered that the yoke base has a very large rod that goes through to the top and has that big sod off nut on it. That means my old fitting designed for a tube won't work.
I also saw a suggestion for the ball on the bar holders but I'd be after something central.
If you've got a part number for the centre nut attachment that would be great!!
Logged
fazer69
CBT Wobbler
Reply #2 on:
07 May 2012, 07:48:48 pm »
hi, i think it was RAM-B-349, I GOT A SPARE NUT, DRILLED IT & PUT A NUT ON THE INSIDE OF THE NUT, TO BE HONEST ITS A BIT LOW DOWN, THE ONE ON THE TOP CLAMP IS BETTER EVEN WITH A TANK BAG ON.
Logged
locksmith
Naughty Corner
GP Hero
Reply #3 on:
08 May 2012, 09:41:17 am »
If it's low you can always use a longer arm on the ball. I've got two, a short one for no luggage and a longer one for when a tank bag is being used.
Logged
violetsdaddy
DAS Born Again
Reply #4 on:
10 May 2012, 04:31:58 pm »
I popped my central mount into the vice and ground/filed off the base fins creating a nice flat surface.
I'll now have a near perfect central fit for the sat nav with the ball mounted on the bar brackets.
I'll post pics when I've got it fitted.
BTW week and a half to my French odyssey.
Hope it stays dry!!
Logged
fazer69
CBT Wobbler
Reply #5 on:
11 May 2012, 01:12:17 pm »
It will be nice to see your pics, good to see how you do it.
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
