Date: 26-04-26  Time: 06:02 am
Author Topic: Rev'Counter Going Wacko Jacko  (Read 15836 times)
Fuzzygoth
« on: 26 September 2011, 05:05:26 pm »
My Rev Counter on my 04 Fazer 1000 when I turn the ignition before starting
the engine it shoots up to 7k rev's for 2 seconds every 6 seconds until I start
the engine and then everything is normal. Anyone know what going on with it
is it an error or fault in the  wire?
Fuzzy
steeeve66
Re: Rev'Counter Going Wacko Jacko
« Reply #1 on: 26 September 2011, 05:49:40 pm »
that looks like an EXUP that needs seeing to - could be the valve itself or just the pulley that's seized or just that the cables need adjusting, others here on the site will know better than me...
PieEater
« Reply #2 on: 26 September 2011, 06:01:14 pm »
Yup that's the EXUP fault code, have you serviced the EXUP recently? Incorrectly tensioned EXUP cables or a stuck valve is probably your cause, have a look here - http://www.cartestsoftware.com/fz1/exupmaintenance.html
The Male Whale
« Reply #3 on: 27 September 2011, 01:29:06 pm »
A good thrapping can usually free off a slightly sticky valve.
On the Gas! :stop
locksmith
« Reply #4 on: 27 September 2011, 07:18:37 pm »
Been a long time since I had one, but doesn't the needle do the 7k thing while the engine is running as well?
steeeve66
« Reply #5 on: 27 September 2011, 08:13:23 pm »
..it didn't on mine, others here may have a different experience tho
Falcon 269
« Reply #6 on: 27 September 2011, 08:18:12 pm »
Yes, tacho reads actual revs for a few seconds, then the fault code, then zero, then back to actual revs.
nickodemon
« Reply #7 on: 27 September 2011, 09:44:10 pm »
I had the same fault with a fazer i bought recently, but after the ride home it freed off. (rev counter fault code stopped) The bike hadn't been getting used for a few months, so it was just a bit sticky. Its worked fine ever since. Usually its best to strip down, give it a good clean and regrease (coppper grease), rebuild it and adjust the cables.
