Date: 26-05-26  Time: 00:11 am
Author Topic: Fazer 800 Running issue - With video  (Read 106512 times)
Jhooch
« on: 20 September 2023, 11:01:08 am »
Hi guys!
Looking for some input on an issue I have with my 2012 Yamaha Fazer 800 14,00 miles. I bought it with the issue I’m trying to fix. I have no history on the bike, the dealer I bought it from couldn’t fix it.
Check out the video of my issue - http://youtu.be/50X8uXyvpzE?si=qrf3s8njx5ULxREP
Originally the fuel pump would be working all the time when you key on, then while running it would have inconsistent revs as shown. With the fuel pump relay not switching off, I fixed this buy getting a used ECU. I thought perhaps it would fix both issues but it didn’t. (I haven’t yet flashed this ECU to my lockset, I’m using an emulator until I can actually get the bike running correctly)
I have no fault codes on the dash, and I have tested the following.
  • Intake Air Pressure Sensor
  • Air Temp Sensor
  • Cam sensor
  • Crank Sensor
  • TPS
  • Secondary TPS
  • All 4 coils
  • Atmospheric pressure Sensor
  • Fuel pump pressure (Sits a 3.0 bar while the issue is happening)
  • Fuel pressure regulator (Changed it just to be sure)
  • Engine Temp Sensor (As shown the revs do come down as the bike gets hotter)
  • Balanced the throttle bodies (Spot on, no need to adjust)
All parts are within spec or either operate to the genuine manual.
Diag tests on the speedo all show and work correctly.
The spark plugs are sooty, so it looks like it’s over fuelling. The bike as far as I know is completely standard. Has standard exhaust, air filter and as both ECUs are showing the same symptoms, I doubt they have been both mapped.
But as the video shows the tacho jumping everywhere, it does feel like it’s missing, pointing to an electrical fault. But with all plugs being sooty, I can see a plug/coil braking down.
I have already checked multiple forums for a fault like this but had no luck.
Is this an issue with Fazers you seen before?
Any input would be greatly appreciated, maybe I’m being a fool and missing something obvious here!
agricola
Re: Fazer 800 Running issue - With video
« Reply #1 on: 20 September 2023, 05:20:25 pm »
Tickover looks way too high to me, should be around 1000 to 1250 I reckon. Also, when you turn the key on, Ibelieve that you have to wait for the tacho needle to sweepm all the way to max revs and backm to zero, to allow it to complete the systems check. Have a real good close look at the rubber sleeves on the injectors to make sure they are all seated correctly
« Reply #2 on: 20 September 2023, 10:47:35 pm »
Sounds like your fast idle plunger sticking.
Jhooch
« Reply #3 on: 26 January 2024, 11:44:57 am »
Appreciate the response guys.
Sorry for the slow update, been super busy.
I've changed the throttle bodies (And all attached sensors) and fuel pump (Pump itself and the regulator). However I still have the same issue, exact same symptoms.
My next step is to check the valve clearances, however with the bike only doing 14K I'll be very surprised if they're out.
If you have any other suggestions I'm all ears.
Will update soon!
« Reply #4 on: 26 January 2024, 08:48:34 pm »
Will the idle not drop if you adjust the idle adjuster? I assume not since that is the obvious first step to check.Did you reset the ECU? It is a learning ECU.Did you check the fuel line pressure? Should be 47PsiWhen you tested the items did you check the wiring connection back to the ECU? Did you check the Multi point earth which is prone to corrosion?Was the fast idle included with the replacement throttle bodies, is it adjusted properly and is a common source of high idle issues.
Has the TPS been set correctly?Did you try disconecting the O2 sensor?
Gnasher
« Reply #5 on: 02 February 2024, 10:10:55 am »
The symptoms are suggesting issues with the cold start circuit.  There are several sensor the ECU uses to control that circuit.  You state you've tested them, try disconnecting the temperature sensors one at a time see if you can get the revs to drop to 1200. Test fuel pump pressure, you'll need a gauge for that. Also check the fuel return circuit ie blocked or restricted.  Check the air box for restrictions or damage eg holes/splits. Look for signs of a boost plug these are plugged into air temperature sensor in the intake, these fail overtime.  Some are home made bodge jobs and cut into the loom, only to be removed on selling.  The std sensor will test ok, but if the loom is damage the circuit won't work correctly.  Check the loom for signs of an alarm having been removed or fitted incorrectly.
From what you've stated, over fueling is your issue, but the problem may well not sit n the fuelling circuit.  But rather one of the supporting circuits.
Jhooch
« Reply #6 on: 08 February 2024, 02:17:54 pm »
So I've just done the valve clearances and to my surprise, most were out of spec. All back together but still have the same symptoms.
I bought a new pattern coil stick, to swap out and test each cylinder, because when the revs do creep down you hear a missing. But made no difference.
- No the idle won't change/drop
- No I haven't, I didn't know you could. I've cleared any memory faults. How do I reset the ECU?
- Yes Fuel pressure is spot on. I only swapped it out because I was starting to not trust my pressure tester. (At least I know my gauge is good  :lol )
- Yeah Earth is decent, cleaned it anyway.
- Yes the fast idle was included. The throttle bodies I purchased were complete as if you just took the throttle cables off. With the new (Used) throttle bodies I'm having the same high idle issues, so I would think they are both factory set.
- TPS has been set within spec.
From what you've stated, over fueling is your issue, but the problem may well not sit n the fueling circuit.  But rather one of the supporting circuits.
- Air Temp Sensor is standard but I will check for any dodging wiring.
- Coolant Temp Sensor is working has the readout on the dash is correct. But I will pull plugs to see if I can get it to act differently.
- No signs of an alarm being fitted.
Thanks for sticking with me guys. I think I'm going to have to start checking pins at the ECU which I'm not looking forward too...
I have an had an issue before with a different bike I owned, where the crank sensor would fail when hot. But it would start missing on all cylinders, acting like a kangaroo.
I'm just starting to wonder if it's starting to die on my FZ8. I can sort of keep the bike running if I keep the revs above 3K so it doesn't make sense the CPS not working at low revs does it??
I'll update again, when I've done the next round of tests/swapping out.
« Reply #7 on: 09 February 2024, 07:50:23 pm »
I forgot to reply to the ECU reset.Disconnect the Positive battery lead leave it off for about 15mins then touch it off the negative lead for a few secs, now put it back on.There are two sensors for firing of plugs and injectors the Crankshaft sensor and the Camshaft or Cylinder Identification sensor. These going bad would be more of a misfire issue, stopping intermittently especially when hot or difficulty starting and/or rich running or stalling
A Throttle position sensor going faulty could cause  the issue, but would be rare and it would most likely be surging when riding slowly. Removing it and turning it manually should show if it is the cause.
It could still be a stuck thermo wax unit as the little piston can seize. Bike that are idle for a long time or bike that are started occasionally and  not allowed heat up fully when left idle for a long time can have corrosion build up on the little piston causing them to stick on or off. It could be stuck on the replacement throttle bodies also.You can probably remove it with out disconnecting the coolant hoses like the FZ1 or you could separate the unit, I am not overly familiar with the FZ8 but it should be similar to the FZ1. The piston should move in and out when cold but only about 5or 6mm. Since you have a spare throttle body you could practice on it first
