Date: 19-04-26  Time: 06:43 am
Author Topic: pilot jets  (Read 6615 times)
fatboy
pilot jets
« on: 06 July 2023, 04:31:07 pm »
hi guys
best way to clean them
and how small is the hole that goes through them,bit of wire brush be small enough
cheers
ben
Re: pilot jets
« Reply #1 on: 07 July 2023, 03:22:28 pm »
I recently did this with mine. I used carb cleaner, a compressor to blow air through the jet, and a bit of wire from a brass wire brush. The jets are made from brass, so any stronger metals (e.g. steel) might damage the them.
fatboy
Re: pilot jets
« Reply #2 on: 07 July 2023, 04:56:46 pm »
thank for the response
have tried all that,soaked in carb cleaner over nite.must be really badly blocked
can you see daylight through yours when clean
think i might have to renew mine.been in there 20 years
regards
ben
Re: pilot jets
« Reply #3 on: 07 July 2023, 05:06:17 pm »
Unless they're visibly damaged, or corroded you should be fine. You can just about see daylight through them when they're clear. A bit of brass wire should do the trick.
fatboy
Re: pilot jets
« Reply #4 on: 11 July 2023, 11:50:56 am »
gave up trying to clear them,must be really badly corroded inside
got some genuine jets,from a company called motocarb
will fit and hopefully the problem is sorted
cheers for the help
Mikuni Pilot & Air Jets - Motocarb
link for there site
BBROWN1664
Re: pilot jets
« Reply #5 on: 20 July 2023, 11:40:18 am »
regards
Remember that one of the three in each carb is actually a blank and is blocked.
fatboy
Re: pilot jets
« Reply #6 on: 21 July 2023, 09:46:00 pm »
Hi
Already sussed that one out lol
Pilots where blocked solid
Cheers
