Date: 19-04-26  Time: 03:11 am
Author Topic: Restarting bike after many years unused  (Read 7508 times)
Farjo
« on: 24 June 2023, 08:56:26 am »
My 2003 Fazer has been unused since about 2015. For time it's been in a garage. This summer I've bought a new battery and changed the petrol. When I press the ignition button it turns over, and seems to want to start, but just won't.
Could it be because the petrol between the fuel tank and the carbs is still the old stuff? If so is it a question of trying and retrying until the new fuel reaches the engine? Or are there other likely causes?
Thanks for any help.
Re: Restarting bike after many years unused
« Reply #1 on: 24 June 2023, 09:22:21 am »
you could drain the carbs off first but the jets may be blocked anyway.
Give it a squirt of easy start to see if it runs on that - this will prove its fuel related rather than ignition related.
Farjo
« Reply #2 on: 24 June 2023, 09:56:53 am »
Thanks for the reply. TBH my abilities won't stretch to being able to do that :lol  What's easy start?
I should have written in the first post that I want to sell it, and am assuming I'll get more for a runner than if someone has to come with a traler. Hense the desire to get it started. But if it's too expensive or time comsuming I doubt it's worth it.
« Reply #3 on: 24 June 2023, 11:01:01 am »
Easy start, comes in an aerosol, Halfords sell it £4.99.
« Reply #4 on: 24 June 2023, 03:57:36 pm »
Hay hay, long time no hear.
As mentioned, it will probably be furred up pilot jets, caused by years of moisture build up.  The only real way to sort them is to remove the crabs and clean them mate.
Sorry there isn't really any other way of sorting it :\ [size=78%]   [/size]
Farjo
« Reply #5 on: 24 June 2023, 05:20:32 pm »
Hi Gnasher. Crabs? Carbs?  :rollin
Thanks for all your help  :)
« Reply #6 on: 25 June 2023, 08:53:31 am »
Carbs might also indicate other cleaning is requited  :b
Farjo
« Reply #7 on: 21 July 2023, 03:19:44 pm »
Just to update this thread... that there's no update  :\
The bike's at my Mum's house and I only had a certain amount of time to dedicate to this. I've been back but there wasn't a moment to spare.
When I'm next there I'll have a go with the easy start - well I got some so I may as well (thanks robbo :) )
In the past I've balanced the carbs several times. Once it's been stripped to that level is it easy to 'drain the carbs off' and look at and clean or replace the pilot jets? Or am I only half-way there at that point?
One other point to mention, when I turned the key it clicked for a while - to be expected of course. But when I next turned the key it did the same. From memory it didn't get to the point where I'd turn the key and it just clicked once or twice. Problem? Clue?
« Reply #8 on: 26 September 2023, 09:32:36 pm »
Battery needs charging.
