Date: 17-05-26  Time: 02:08 am
Author Topic: Nose cone & headlights  (Read 4128 times)
ArchDruid
« on: 24 February 2023, 07:43:35 pm »
So, besides my modified Fazer, and FZR, and a YZF, I'm busy building another 'special'.
Which of you knowledgeable & experienced people can tell me what the differences are between the fox eye versions of the 1000 and the 600. I'm looking to buy a nose cone, headlights & mounting bracket for a separate (non- Fazer) bike project. I was leaning towards the FZS 600 fox eye set, but have been offered one from a 1000.
Question is mainly around the sizes..., not worried about mounting arrangements  - those will be modded to suit anyway.
Are the 1000 versions narrower than the 600 versions ?Any other arbitrary info would help...
Thanks !!
Gaz66
Re: Nose cone & headlights
« Reply #1 on: 27 February 2023, 03:36:58 pm »
Hi Pal.
What info are u specifically looking for?
If it's measurements of a 1000 nose cone, I can help with that, 1000 is defo a bigger unit than a 600, both look very similar from 20yards away but very different up close.
ArchDruid
« Reply #2 on: 01 March 2023, 02:55:46 pm »
Width across the nose (widest point) would be helpful (for the 1000)
Interesting to note that the headlights have the same part number for 600 & 1000 (5LV-8431000)
And the cowl part numbers are similar, with only the model identifier being different 5RT-2835G-00-P2 v 5LV-2835G-00-P2
Thus the question 'whats different ?'   particularly if considering the above & you understand the structure of the yamaha part number convention ...
Cheers
