Date: 24-04-26  Time: 21:31 pm
Author Topic: Reg Rec Wiring  (Read 3200 times)
Slippy
Reg Rec Wiring
« on: 29 September 2022, 04:28:22 pm »
Hello!
The reg/rec on my fzs 600 2003 has melted the connectors! It also has been rewired so a standard oem rec/reg wont fit any more.
Few questions!
  • Does the order of the white wires matter when connecting to the reg/rec ?
  • Could i just hard wire it with my new reg/rec ?
  • If no on number 2, what connector do i need and any advice / tutorial on how to fit the wires into the connector ?
Thanks all!
agricola
Re: Reg Rec Wiring
« Reply #1 on: 30 September 2022, 09:57:53 am »
1) No
2) Yes, but good, clean soldered joints, well insulated from each other.
3) If you are buying a new RR, I believe that you can unclip the spades from the connector plug and purchase a replacement male and female connector for both ends. I have used this company before https://www.vehiclewiringproducts.co.uk/
Re: Reg Rec Wiring
« Reply #2 on: 30 September 2022, 03:16:06 pm »
45a Anderson Power Poles are the best solution and is what I used back in 2017. Neat finish and can be disconnected easier than the original was before burning out
midden
Re: Reg Rec Wiring
« Reply #3 on: 01 October 2022, 07:04:49 am »
How often do you need to disconnect it?
Slippy
Re: Reg Rec Wiring
« Reply #4 on: 01 October 2022, 09:12:50 am »
Thanks for the replies!
I’m just going to hard wire it, been advised by a mechanic friend that crimping it would be the best solution so will do that.
Can’t be bothered with adding new connections to faffy and could melt again!
Thanks all
Re: Reg Rec Wiring
« Reply #5 on: 02 October 2022, 12:28:35 am »
You would only need to have to do it once
