Date: 17-04-26  Time: 21:31 pm
Author Topic: yamaha fazer fzs 600 pick up coil  (Read 2958 times)
neilr
« on: 14 February 2021, 12:41:14 pm »
Hi
just check my pick up coils as ive no spark at the plugs, my meter is reading just over 197 ohms between pins on the pick up loom. does anyone know if this reading is within specification as I cant seem to find any specs and my Haynes does not have it either. Also what output should the pickup be sending to the tci(pulse i believe its called)
Thanks
Gnasher
Re: yamaha fazer fzs 600 pick up coil
« Reply #1 on: 14 February 2021, 01:40:30 pm »
Primary coil resistance should be between 1.87 and 2.25 across the low tension circuit and the secondary including the lead is 12-18 k ohms, resistance for a cap is 10 ohms.
You'll more than likely find the issue is the plug lead either where in goes into the cap or coil, both can be trimmed back, that said it's possible that's already been done and you may need new leads. It's also possible a/the cap/s have failed.
BBROWN1664
« Reply #2 on: 14 February 2021, 02:01:23 pm »
The yamaha manual is in the download section of this forum. Much better than Haynes for things like this.
grahound
« Reply #3 on: 15 February 2021, 06:45:57 pm »
Pick up resistance =189-231 @20 deg c
