Date: 18-03-26  Time: 02:17 am
Author Topic: R1 Clocks Switch - Electrical help  (Read 2756 times)
Jbizzle
« on: 21 October 2020, 11:11:10 pm »
Can anyone with a bit of electrical know how give me a hand with this?
I'm trying to switch the clocks on my 2000 plate FZS600 with a R1 (5JJ) clocks.
I have the R1 front end on the bike, having the corresponding speed sensor / clocks seemed like a good idea at the time :rollin
I'm struggling with working out what's what, on the R1 terminal from the wiring diagram.
Perhaps I am going about it the wrong way?
Disorderlypunk
Re: R1 Clocks Switch - Electrical help
« Reply #1 on: 22 October 2020, 04:00:25 pm »
if you ever get it sorted and working right please let us know cause it seems like a nice little upgrade
kebab19
« Reply #2 on: 22 October 2020, 05:44:08 pm »
Is it the same as the early FZ1/FZS1000 sensor running from the front sprocket?  If so, why not just run it to the original clocks as forum member Muddybuddy did?
http://foc-u.co.uk/index.php/topic,14254.msg162228.html#msg162228
Jbizzle
« Reply #3 on: 27 October 2020, 08:15:05 am »
Hi Kebab.
I could do but i kind of want the challenge of getting these to work.
I will document it all in case it does come off then anyone else who wants to give it a bash has an initial leg up.
Does anyone know if i can actually narrow down each wire in the loom using the wiring diagram?
Cheers,
James
ben
« Reply #4 on: 28 October 2020, 06:55:54 pm »
Are you trying to connect the R1 main harness to the Fazer? Or are you trying to connect the Fazer wiring to the R1 instrment panel?
Jbizzle
« Reply #5 on: 29 October 2020, 11:58:36 am »
Hi ben,
I am trying to connect the R1 instrument panel, to the Fazer main harness.
The bike is a FZS600 2000 (5DM). With the normal loom etc.
But the Clocks/ instrument panel are off the R1 (5JJ).
So I will be using the connector for the R1 instrument panel, from an R1 front loom that I purchased. Then cutting off the wires at the  at the loom end, then matching up each of the wires function,  with the Fazer wires by colour.
Disorderlypunk
« Reply #6 on: 29 October 2020, 02:14:54 pm »
have a look at
http://www.robcollingridge.com/kitcar/design/engine/clocks.html
might be a bit of help to figure some of it out
ben
« Reply #7 on: 29 October 2020, 03:13:09 pm »
I've attached an update to your spreadsheet. This shows (I hope/think) what wires from the R1 are going into the instrument cluster. I guess the next step find the equivalent wires on the Fazer wiring diagram.
Jbizzle
« Reply #8 on: 29 October 2020, 04:54:53 pm »
Ben, mate you're a legend.
I will give it a crack in the next month or so.
