Date: 05-05-26  Time: 23:47 pm
Author Topic: Secondary flies - I did a BOBO!! Anyone here?  (Read 3226 times)
killerwhaleTRX
« on: 06 August 2020, 02:51:10 pm »
So, i was to install copperdawgs flies. Had a torch and everything but absolutely no go!! The screws actually looked oval!
Anyways, i adjusted on the spring loaded screw a bit and became to curious. Thought i had the spring with one finger but no...it shooted down in the injector thingie...cant get it up.
Any good ideas? Got a motorlight now of cource.....supid arse me....
HELP! :)
Gnasher
Re: Secondary flies - I did a BOBO!! Anyone here?
« Reply #1 on: 06 August 2020, 03:42:21 pm »
Do you mean the throttle body?
killerwhaleTRX
« Reply #2 on: 06 August 2020, 04:07:08 pm »
Yeah, tried getting hold of it with a magnet but its under the rubbers somewear :(
Anyone know what the spring actually do? Have put a straight screw in there now and it does the same....by the look of it.
killerwhaleTRX
« Reply #3 on: 06 August 2020, 04:21:57 pm »
ALSO, have no manual here at work. The black mikuni part sitting on the servomotor....is that the actual motor??
Asking because it looks like a TPS...and then i´m bloody screwed.
If its the motor, can i just unmount it and zip tie the secondaries?
Gnasher
« Reply #4 on: 06 August 2020, 04:23:18 pm »
Are you saying it's gone past the secondary butterfly (the one you was trying to change) and down into the throttle body or just down somewhere, where the throttle body meets the head?
I think you'll referring to the secondary butterfly servo motor damping spring, to the TPS unit, just above where the chaps thumb is under the nut?
killerwhaleTRX
« Reply #5 on: 06 August 2020, 04:39:29 pm »
Thats the spring, NOT gone INTO the engine at all.
My 2008 looks a little different?
On the end of the shaft of the servo wich opens the seconds there are a nut.
Any chance of taking that off and get the arm off? Then one can ziptie the seconds open with the other arm i guess....
Gnasher
« Reply #6 on: 06 August 2020, 04:55:50 pm »
Those are 08 bodies there the same 06 - 12 are pretty much the same.  I think you're talking about what's under the cover below his little finger, if it is picture would help?
If it is that's the sub or secondary throttle position sensor adjuster, mechanism spring.
killerwhaleTRX
« Reply #7 on: 06 August 2020, 05:39:57 pm »
Got to limper home so i drove the arms together with a screw....
Beer and ebay tonight! :)
DAM guys!!
The bike couldnt care less of the lost spring, when screwing arms together secondaries was actually more open and i think it was....peppier.
What i DID DO before "limpering" home was that i uninstalled the autotune again just because the connection was so bulky and i couldnt figure out a good way to hide it....
BAM and the engine light was gone...
When i will learn to just do one mod at the time i dont know but....YAY  :b
