Date: 07-05-26  Time: 12:11 pm
Author Topic: Bikes died 😧☹  (Read 35114 times)
Gnasher
Re: Bikes died
« Reply #25 on: 27 June 2020, 11:12:25 am »
On the rare occasions I've had to deal with generator issues (not FZ1) it's the coil assembly that's been the problem.  That said there was/is an issue with early models of FZ1 08 - 09 in that the magnets became dislodged from the stator drum and stopped charging and/or destroyed themselves, in extreme cases wrecked the motor.  Yamaha changed the design of the drum and effectively fitted a sleeve to prevent the magnets from dropping, new part No 2SH-81450-00, old part 5VY-81450-00.  Check the part No on yours, if it's the latter, it's very likely this will be your problem and a change of the rotor assembly, could well sort it but wait for it £675 :eek
A contact suggested these https://www.motoelectrical.co.uk/types/stator-coils-/flywheel-rotor-yamaha-yzf-r1-fz1-1000-fzs1-fz8-800-2004-2015/?gclid=Cj0KCQjw3Nv3BRC8ARIsAPh8hgKQrLj_Vuvh7KUwLSg9UWGR86qCXT-WlLi_ibWkhiMVZ6dqGMa_xjAaAiv6EALw_wcB  £214
Or I found this https://www.ebay.co.uk/i/264477816095?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=264477816095&targetid=908661247816&device=c&mktype=pla&googleloc=1006675&poi=&campaignid=10199419183&mkgroupid=101401896465&rlsatarget=pla-908661247816&abcId=1145983&merchantid=6995734&gclid=Cj0KCQjw3Nv3BRC8ARIsAPh8hgIFzxnXZRTgU8dux2SbIC4zs8DFYN09BjfGojbrUjUXUfloSRGiakQaAjBfEALw_wcB Which is genuine and the later part £370
If it does turn out the rotor assembly is the later type, the coil assembly is then more likely the issue, I'd go for either new £355ish, second hand OE around £150 ish.
Or you could go pattern part as with any pattern part I would advise caution, that's not to say they're wont work, they will, it's just for how long and often they don't quite always fit as they should!  You've also got wild variation in cost, Wemto part https://www.wemoto.com/bikes/yamaha/fz1_n/08-09/picture/generator_-_stator is £219ish for what looks like the MPW offering https://www.motorcyclepartswarehouse.co.uk/mpw-pattern-replacement-stator-generator-assembly-yamaha-fz1-fazer-2006-2012.html which is £46.99 not sure if that's inc VAT but that's a huge difference!
Both are probably Chinese copies, it's your choice.
If you've not removes a generator assembly before, undo the centre cap but don't undo the 3 small bolts around the cap cover. Undo all the bolts around the cover these are different sizes, now use a a lager Phillips screwdriver or Allen key to push on the stator drive shaft.  This will allow you the remove the coil assembly while keeping the rotor drum in place, it will be very magnetic and require a really good straight pull.  If you allow the rotor drum to be extracted with the cover you run the risk of dropping the shaft spacer and washer into the crankcase.  Even when you do it this way there's still a risk, but much smaller, once you've got the cover off, very smoothly pull the rotor drum out, the drive gear should remain in place.  Now look through the hole in the gear centre, you should see the displaced spacer washer, using the screwdriver/key insert into the gear hole until it stops, now you can pull out the gear, be very careful as behind the washer is the spacer. you should be able to get the gear/washer and spacer onto the screwdriver/key.
Dudeofrude
Re: Bikes died 😧☹
« Reply #26 on: 27 June 2020, 12:48:39 pm »
Thanks for the info Gnasher. Very helpful 👌
I've had that £214 one saved for while as its a job I've been meaning to get round to ever since I heard about them failing.
I've watched Andys (andymancam) video of him doing the change and looks simple enough. I'm just waiting for a gasket to show up before I take the cover off for an inspection. I'm guessing that if the flywheel magnets are all still intact then it will have to be the coil thats blown
New battery here Monday so worst case scenario it will have enough power to get it to my mechanic if I can't figure it not myself
Gnasher
Re: Bikes died
« Reply #27 on: 27 June 2020, 01:16:12 pm »
Your're welcome.
I'm not an expert at testing of electrical components, I've got people I can call on if I cn't suss it.  One of those contacts suggested following this guide http://https://www.r1-forum.com/threads/how-to-charging-system-fault-finding.294687/ which should help you identify which of them is giving you the problem, the system here is an R1 but they're the same just follow the values in the FZ1 manual if different.  Obviously you need to be able to understand and use an multi tester.
Good luck let's us know how you get on.
Dudeofrude
Re: Bikes died 😧☹
« Reply #28 on: 29 June 2020, 12:56:57 pm »
Well brand new Yuasa battery went in today and still no change. Runs at 12.65v and doesn't change while loading the throttle. So now just waiting for the stator cover gasket to arrive and that will be getting whipped off for an inspection.
At this point I'm more or less sure its going to be the magneto issue that they all seem to suffer from so just hoping the magnets are all they and accounted for so I don't have to go fishing in my sump 😬
BBROWN1664
Re: Bikes died 😧☹
« Reply #29 on: 29 June 2020, 01:38:48 pm »
daft question time. Have you checked the voltage input on the regulator/rectifier rather than assuming its a generator (coil/magneto issue)? These are known to fail on almost every bike at some point.
Dudeofrude
Re: Bikes died 😧☹
« Reply #30 on: 29 June 2020, 01:47:30 pm »
I have to the best of my ability. I'm not 100% sure about the numbers but everything tested came back with consistent readings.
The reason I believe its the rotor is because the bike doesn't get to 14v even while running. From what I've been told that points to the magneto/rotor as the bike is not receiving any charge?
BBROWN1664
Re: Bikes died 😧☹
« Reply #31 on: 29 June 2020, 02:53:06 pm »
the regulator/rectifier sits between the coils, which produce AC voltage having had the magnetic field applied and removed rapidly, and the battery, that needs DC voltage.
Dudeofrude
Re: Bikes died 😧☹
« Reply #32 on: 29 June 2020, 03:07:43 pm »
Yeah i took the rectifier off and tested the points which as I say came back consistent but I've no clue as to whether that means its working properly?
The other reason I'm convinced its the rotor is that when I tested the lead coming from it the results were all 0.7 when the workshop manual says the spec is 0.14-0.18 so there isn't enough power actually coming from the rotor to the rectifier in the first place
b1k3rdude
Re: Bikes died 😧☹
« Reply #33 on: 29 June 2020, 03:51:41 pm »
Is is thread for an FZ1? if so prolly should be move to that section so when the fix is found other FZ1 owner can be made aware.
Dudeofrude
Re: Bikes died 😧☹
« Reply #34 on: 29 June 2020, 04:10:40 pm »
It is mate but I originally posted here to get the attention of more members who may have been able to help as not everyone visits every section.
The admin can feel free to move it to the FZ1 section if they want? I have no way of doing that (as far as I know) 👍
Gnasher
Re: Bikes died 😧☹
« Reply #35 on: 29 June 2020, 05:14:09 pm »
Test the voltage coming from the generator at the plug with the bike running, just a small rev should give you 13v plus, if not it's the stator of the rotor.
Dudeofrude
Re: Bikes died 😧☹
« Reply #36 on: 29 June 2020, 05:30:35 pm »
Will give that a go shortly then 👍
Stupid question but do I start the bike then unplug the stator from the rectifier? Or will it start without it connected?
Gnasher
Re: Bikes died
« Reply #37 on: 29 June 2020, 06:02:40 pm »
Oh forgot to mention, from the generator you'll get AC not DC volts and at idle around 14v if it's good, as you rev it will increase with the revs, 2k =20v, 3k, 30v etc etc up to around 70v ish from memory if it's good.
I think (from memory but I could be wrong) you should be able to get at the wires through the back of the plug that goes into the rectifier.   Take a good look at the link I sent you over the weekend ref R1, it's all in there just follow it and remember you've got to do some maths when you test the ohms on the generator.
Dudeofrude
Re: Bikes died
« Reply #38 on: 29 June 2020, 06:07:41 pm »
I've been testing it using the ohms setting (resistance) as thats what it said in the service book? And ive tried to get the prongs into the back of the plug but can't do it without damaging the wires
Gnasher
Re: Bikes died 😧☹
« Reply #39 on: 29 June 2020, 06:11:50 pm »
Just edited my last post, ref Ohms testing take a look.
Dudeofrude
Re: Bikes died 😧☹
« Reply #40 on: 29 June 2020, 06:17:54 pm »
Gnasher
Re: Bikes died 😧☹
« Reply #41 on: 29 June 2020, 06:21:21 pm »
It's the maths on Ohms that's the important bit, all in the link mate.
Dudeofrude
Re: Bikes died 😧☹
« Reply #42 on: 29 June 2020, 07:16:35 pm »
Right I think I've tested it right. I disconnected the plug with the 3 white wires from the rectifier, turned the bike on and left it to idle, switched my multimeter to AC and then inserted the prongs into each of the wires in the connection plug but didnt get a reading from any of them?
I then tested the resistance again and got the same reading of 0.9 from each wire?
That guide said something about testing the multimeter first then deducting the numbers but when I did that the multimeter was reading 1.5 and the wires were only 0.9 (which is half the recommended spec) so that would mean a reading of -0.6 🤷‍♂️🤷‍♂️
Either way I think its getting pretty conclusive that its the stator thats failed?
Gnasher
Re: Bikes died 😧☹
« Reply #43 on: 29 June 2020, 07:36:17 pm »
Yep, from what you're saying looks like it shot mate  :(
If it's the coil pack/assembly the copper coils normally look very dark burnt and can smell the same.  If when you get the rotor assembly off it's not got the inner sleeve on (early type) look at the magnets check for lose damage, you may just want to change it anyway for the later type.
b1k3rdude
Re: Bikes died 😧☹
« Reply #44 on: 29 June 2020, 08:14:14 pm »
I haven't read the whole of your thread, but if you still have the old rotor in the bike you should really replace that along with the stator.
Motoelectrical do quality pattern parts and for your first purchase you get 10% off so the stator/rotor kit would be just over £300 -
https://www.motoelectrical.co.uk/search/index/?category=0&keyword=FZ1&refine=Search
Or I found this on ebay, looks like a reconditioned part as it only has a 6m warranty -
https://www.ebay.co.uk/itm/Replacement-Stator-Generator-Magneto-Assembly-Yamaha-FZ1-S-Fazer-06-15/333309772313?epid=10025226535&hash=item4d9acf8219:g:Gt8AAOSwGfZdZk-k
Dudeofrude
Re: Bikes died 😧☹
« Reply #45 on: 29 June 2020, 08:32:00 pm »
Cheers for the links. I will be replacing the rotor if its original regardless, but that is a decent price for the 2 parts new.
 Will know what I'm working with by the end of tomorrow 👍
Dudeofrude
Re: Bikes died 😧☹
« Reply #46 on: 30 June 2020, 01:39:09 pm »
Well I've found the problem 😔😔
Dynspud
Re: Bikes died 😧☹
« Reply #47 on: 30 June 2020, 02:29:03 pm »
Jeepers mate; that's a right mess  :'(
I hope you get it sorted  :thumbup
Dudeofrude
Re: Bikes died 😧☹
« Reply #48 on: 30 June 2020, 02:36:04 pm »
Well I've just ordered a new rotor and stator from one of the links in this thread (thanks guys) so that should be here in a few days.
There's only 1 or 2 magnets that are actually broken and all of the parts seem to be stuck to the stator so I'm not too concerned about metal in the engine.
I will change the oil and have a route through it with a magnet to be certain but I'm hopeful that it should be simply a case of old out and new in... job done 🤞🤞
snapper
Re: Bikes died 😧☹
« Reply #49 on: 30 June 2020, 03:47:19 pm »
ouch that looks nasty
 to be honest I think you've got away lightly that good of been so much worse
