Date: 13-05-26  Time: 04:20 am
Author Topic: Pipe Inlet Rubber Cap Thingy?  (Read 3390 times)
WayneUK
« on: 30 May 2020, 11:03:30 am »
Does anyone know what I can use or get the rubber caps that fit on the spigot on the pipe inlets?
WayneUK
Re: Pipe Inlet Rubber Cap Thingy?
« Reply #1 on: 30 May 2020, 11:31:14 am »
Also is it ok to run the bike with one of these missing?
vinnyb
« Reply #2 on: 30 May 2020, 12:03:00 pm »
https://www.ebay.co.uk/itm/Motorcycle-Vacuum-Pipe-Rubber-Cap-MotorBike-Blank-covers-Carb-Balancing-Inlet/124014279398?hash=item1cdfd3bae6:g:wT8AAOSwL9Bd-Pmc
 Do you mean one of these?
 I wouldn't have thought it would run particularly well with one missing, it'll let excess air into the system.
WayneUK
« Reply #3 on: 30 May 2020, 12:15:12 pm »
Yes there them, thank you, I used to have the scottoiler connected to one, do they not blow air?
vinnyb
« Reply #4 on: 30 May 2020, 12:16:04 pm »
 OEM part number is 16G13569-00, available from fowlers @£2.32 each but P&P will be pricey
vinnyb
« Reply #5 on: 30 May 2020, 12:19:46 pm »
No they suck, the scottoiler works on a vacuum, they're there to attach carb balancing vacuum gauge pipes to.
tex
« Reply #6 on: 30 May 2020, 12:27:10 pm »
 Do you have a link to buy the clips that go with them , thanks
vinnyb
« Reply #7 on: 30 May 2020, 12:32:58 pm »
OEM part number 90467-10039 @ £1.66 each, also in stock at Fowlers.
