Date: 14-05-26  Time: 16:31 pm
Author Topic: Tips for a FZ1S 2006 GEN 2  (Read 5795 times)
CatalinU
« on: 12 May 2020, 08:12:39 am »
I have a gen 1 Fazer, wich I have modded after most recomanedations. Now i found a cheap FZ1S, gen 2. What are firsts things to do? I was reading about ECU flashing at Ivan. Anything else on to do list?
Dudeofrude
Re: Tips for a FZ1S 2006 GEN 2
« Reply #1 on: 12 May 2020, 10:19:52 am »
Lars airbox mod plus a free flow air filter, decat headers and add aftermarket can, Power commander with custom fueling map, drop down to a 16t front sprocket, remove AIS (if you don't like a popping exhaust and want easier access to plugs)
That's just a few of the bits I've done to mine 👍
bernieeccles
« Reply #2 on: 12 May 2020, 07:55:45 pm »
I did all those mods on my 2008 and buggered around with lots of custom maps then decided stock with just a Fuel titanium can was the most pleasant to ride. Got sick of the increased induction noise from the airbox mod so stuck the cut plastic back in.
It's plenty fast enough as standard. The only other mod was a Nitron rear shock which I then sold when I sold the bike. Also put Renthal bars on.
CatalinU
« Reply #3 on: 13 May 2020, 07:50:48 am »
AIS will beb locked definitely, where can I get all the info regarding the air filter mods? It will come with an aftermarket end can, don't know about the cat if it has or not
Dudeofrude
« Reply #4 on: 13 May 2020, 08:56:34 am »
This is the best guide I could find on short notice
https://www.instructables.com/id/FZ8-airbox-mod-and-AIS-blocking/
It's for the FZ8 but it's all the same as FZ1 👍
As for decatting the headers, you just have to take the end can and link pipe off then shine a torch into the collector end of the downpipes, if you can see straight through then it's been done, if not you will see the white honeycomb stuff about 4 inches in.
To get it out I just used a drill, hammer and chisel.
Just remember though once you've done the airbox and cat you will need the fueling sorting as it will be running super lean if not
c.swilkins
« Reply #5 on: 15 May 2020, 12:02:41 pm »
Im guessing everyone knows about Andy Man Cam on you tube, he has some interesting vids with mods to his FZ1 very informative too.
Dudeofrude
« Reply #6 on: 15 May 2020, 12:51:33 pm »
Yeah he is a member here, just can't think of his username 🤔
CatalinU
« Reply #7 on: 16 May 2020, 07:57:44 pm »
Following him aswell
CatalinU
« Reply #8 on: 17 May 2020, 07:31:23 pm »
Speaking of Andy, I seen he eliminated the function of the exup valve. Having the GEN 1, it is not recomended to eliminate the valve. Isn't the same thing for the GEN 2?
Dudeofrude
« Reply #9 on: 17 May 2020, 07:50:57 pm »
No it's just for noise regulation on the gen 2. It's in the end can anyway so if you put on an aftermarket exhaust then you'll have to disconnect it all anyway.
I completely removed it all including the servo and install a servo delete. No real need to, just freed up some space under the seat and saved a tiny bit of weight haha
CatalinU
« Reply #10 on: 18 May 2020, 06:58:51 am »
OK, then. Good to know that
CatalinU
« Reply #11 on: 18 May 2020, 09:04:04 pm »
I have seen Andy changinf the rotor, with the improved version. The bike that I am planing to get has 80k km. Did anyone changed this part?
b1k3rdude
« Reply #12 on: 12 July 2020, 09:13:03 am »
There is now a new pinned thread with a lot of the into your after -
- http://foc-u.co.uk/index.php?topic=26286.msg317396#msg317396
