Date: 21-05-26  Time: 05:58 am
Author Topic: bleeding the back brake???  (Read 5036 times)
adam1000
« on: 07 April 2012, 12:57:20 pm »
Does anybody know of any tricks to sucessfully bleeding the back brake? i have fitted a new hose and used the traditional bleeding method, i have no air bubbles coming through but its still not near as good as it was!!
mcyoungy
Re: bleeding the back brake???
« Reply #1 on: 07 April 2012, 01:15:30 pm »
I use a syringe on the bleed nipple to put suction on the line then keep pumping. If the pedal is soft you've still got air in the caliper.
garysimmo
« Reply #2 on: 07 April 2012, 02:44:02 pm »
disconnect the soft hose at the reservoir end and get yourself a wider ended syringe. then crack the bleed nipple and apply pressure from the res end this then gets rid of any air that may get trapped in master cylinder
bludclot
« Reply #3 on: 07 April 2012, 08:53:11 pm »
letting the fluid stand over night often helps matters, it then bleeds to a firm lever easily the following day.
slappy
« Reply #4 on: 08 April 2012, 01:21:35 pm »
i found that dumb perserverance worked,about two bloody hours of it!
mcyoungy
« Reply #5 on: 08 April 2012, 02:35:32 pm »
can't beat dumb perseverance!  :lol
adam1000
« Reply #6 on: 08 April 2012, 11:56:38 pm »
ended up wedging the brake pedal down overnight with the lid off, tried it this morning and bang on!
Falcon 269
« Reply #7 on: 09 April 2012, 06:15:19 pm »
Possibly a dumb question but have to check ... you are using both bleed nipples, no?
bikerally
« Reply #8 on: 10 April 2012, 09:23:57 am »
i bought a mityvac vaccum pump from hein gericke and it worked great, done mates brakes & its now paid for its self.
