Date: 25-05-26  Time: 12:44 pm
Author Topic: Gen 2 wobbly mirror  (Read 2031 times)
malc
Gen 2 wobbly mirror
« on: 05 December 2018, 04:44:34 pm »
Anyone got a cure, my right mirror is a bit wobbly, it's from the base of the stem where it has a large pin under the plastic cover, if i fold the mirror it's not wobbly, wondered if anyone has had the same issue and if there's a way to pack it out somehow ?
Re: Gen 2 wobbly mirror
« Reply #1 on: 05 December 2018, 10:05:49 pm »
Got a picture of it, as I have some patter gen 1 mirrors..
mw2018
« Reply #2 on: 18 December 2018, 11:20:28 pm »
my left one wobbles a bit, i took it off and looked underneath it but it's kind of pressed together with nothing you can adjust or tighten up. so i put up with it, think of it as character. 8)
NorthWestern
« Reply #3 on: 20 December 2018, 07:17:46 am »
My first gen 1 had this issue. I drilled out the rivet, the spring washers had corroded inside the hinge so I ordered new springs off ebay (about 60p).  While I waited for delivery I built it back up with a washer to compensate for the missing springs which was OK but couldn't be folded back properly... You could just bolt it up solid.
FZ1obp
« Reply #4 on: 20 December 2018, 04:56:35 pm »
I've had this a few times on my 2009 Gen 2:
Unbolt the mirror and remove the boot, take two sockets and place one each side of the thin tube that's holding the mirror assembly together and gently apply pressure in a vice to the sockets so that the tube is lightly compressed (ie the sockets need to be sized so that are bearing on the rim of the tube).
Might take a couple of goes
Then re-assemble and check it's wobble free. If not repeat.
Hope it works
malc
« Reply #5 on: 30 December 2018, 02:05:39 pm »
Thanks for the replies, it's not too bad at the moment but when I next have the fairing lowers off (need to be off to get the inner out) then I'll try the 2 sockets and press.
