Date: 25-05-26  Time: 12:43 pm
Author Topic: FZ1 Gen 2: handguards/muffs?  (Read 4128 times)
FZ1obp
« on: 22 November 2018, 02:03:31 pm »
Guys
Need a bit of advice please: have fitted Oxford muffs before and while they do keep hands warm they collapse onto the levers at remotely high speeds. I've heated grips and prefer to ride with summer gloves hence the need for a bit more wind protection.
Any other options that fit the bike and work ok? - don't care what they look like!
Thanks
ogri48
Re: FZ1 Gen 2: handguards/muffs?
« Reply #1 on: 22 November 2018, 06:55:51 pm »
following daves advice (dynspud) I complimented my heatd grips with barkbusters...bloody brilliant and I think they look as if they shoul be there. Today was a very, very cold ride home, and didn't have the heated grips on above halfway. I also no longer get that finger I leave over the brake lever freezing whilst the others are toastily wrapped around oxfords finest intelligent heated grips..
ogri48
« Reply #2 on: 22 November 2018, 06:57:36 pm »
btw I know its a gen one, but they do fitting kits for all types of bar and bike. not cheap (mine were eighty quid with the quality brackets) but well worth it..used the honda for a freezing rain funeral cortege run 180 miles away in kent on Monday. its got heated grips but Christ I missed the barkbusters. and the fairing, such as it is.. :'(
Dynspud
« Reply #3 on: 22 November 2018, 08:11:04 pm »
Glad the Barkbusters are working well for you mate  :thumbup
They do look good on the Gen 1 in our colour scheme as well don't they?
« Reply #4 on: 22 November 2018, 08:46:51 pm »
+1 for barkbuster storms. Seen them on the gen2 too and they fit well as I believe they are a universal fit.
Does effect your turning circle at slow speed but not a problem when you're under way.
Rob R
« Reply #5 on: 22 November 2018, 08:58:40 pm »
+ another for Barkbuster Storms. Be careful with fitting- they can be a bit close to the standard screen on full lock.Rob
old son
« Reply #6 on: 23 November 2018, 06:55:39 am »
What kit did you use on the Gen 1? There are different types. I know I could ask the manufacturers but you guys are not selling them and have had the hassle of fitting them. Thanks.
Dynspud
« Reply #7 on: 23 November 2018, 08:08:50 pm »
This is the link to the ones on mine and Ogri's Gen 1 bikes:-
https://barkbusters.net/what-fits-my/yamaha/fzs1000-2001-2005/storm/single-point-mount/
Flooky
« Reply #8 on: 24 November 2018, 09:00:12 am »
Will these fit my gen 1 with renthal bars ? cheers
Dynspud
« Reply #9 on: 24 November 2018, 10:59:38 am »
The link I gave is for 22mm (7/8") dia bars, which is the standard FZS 1000 Gen 1 size.
They also do them for 1" dia bars.
It depends on the diameter of your bars.
old son
« Reply #10 on: 24 November 2018, 05:01:52 pm »
FZ1obp
« Reply #11 on: 25 November 2018, 07:00:30 pm »
Thank you !!!! I'll check the Barkbusters out sounds like they should fit a Gen 2.
Many thanks for the photos as well - they look pretty smart.
cheers guys.
old son
« Reply #12 on: 26 November 2018, 06:29:23 am »
A big thanks from me too!
FZ1obp
« Reply #13 on: 20 December 2018, 04:49:42 pm »
GuysAfter a bit of searching about have fitted Barkbusters Blizzards to the Gen2 FZ1 that are fabric with a supporting armature/support to stop themcollapsing onto the levers (unlike the Oxfords I used to use) and althoughthey do touch the fairing on full lock they give a little so not a problem.
Used them last weekend - rain/sleet and 2 degs C on the m/way and report allwarm using nr 2 setting on the Oxford heated grips - am hoping that I can goback to summer gloves now for the winter.A big thanks to A2 motorcycles in Gravesend who provided the advice, had theBlizzards and the important Aluminium adaptors that thread into the Yamhandle bar ends on the shelf.
FZ1obp
« Reply #14 on: 20 December 2018, 04:57:44 pm »
Guys[/size]After a bit of searching about have fitted Barkbusters Blizzards to the Gen2 FZ1 that are fabric with a supporting armature/support to stop themcollapsing onto the levers (unlike the Oxfords I used to use) and althoughthey do touch the fairing on full lock they give a little so not a problem.Used then last weekend - rain/sleet and 2 degs C on the m/way and report allwarm using nr 2 setting on the Oxford heated grips - am hoping that I can goback to summer gloves now for the winter.A big thanks to A2 motorcycles in Gravesend who provided the advice, had theBlizzards and the important Aluminium adaptors that thread into the Yamhandle bar ends on the shelf. Tried to upload images but it keeps crashing.
FZ1obp
« Reply #15 on: 20 December 2018, 05:02:46 pm »
Guys
For whatever reason the text I uploaded isn't readable....
After a bit of searching about have fitted Barkbusters Blizzards to the Gen 2 FZ1 that are fabric with a supporting armature/support to stop them collapsing onto the levers (unlike the Oxfords I used to use) and although they do touch the fairing on full lock they give a little so not a problem.
Used then last night - rain/sleet and 2 degs C on the m/way and report all warm using nr 2 setting on the Oxford heated grips - am hoping that I can go back to summer gloves now for the winter.
A big thanks to A2 motorcycles in Gravesend who provided the advice, had the Blizzards and the important Aluminium adaptors that thread into the Yam handle bar ends on the shelf. About £90 all in about 30 mins to fit.
Mustang
« Reply #16 on: 21 December 2018, 08:27:50 am »
+1 for bark busters storms, using the single bar fixing it allows the end of the guard to collapse against the screen at full lock. Although I made the mistake of pulling the bike onto the main stand with the handlebar and broke this large screen. I now have a narrower screen fittted and always pull on the crash bars to stand it up. I did get these guards for £50 off eBay though.
