Date: 22-03-26  Time: 15:01 pm
Author Topic: how much for a replacement cam chain fitted  (Read 9922 times)
zarniwoop
« on: 05 April 2012, 10:42:48 am »
my cam chain is rattling  :(
I've had the adjuster off but not change.
how much do you think it will cost to get it replaced.?
just off to try the, removing the plugs and roll bike backwards in a low gear thing.
Z
kebab19
Re: how much for a replacement cam chain fitted
« Reply #1 on: 05 April 2012, 10:50:32 am »
Check the old Foccer site for 'Subby' having his changed - might mention prices too
zarniwoop
« Reply #2 on: 05 April 2012, 10:50:46 am »
Oh it's an FZS600 2000 model.
Z
zarniwoop
« Reply #3 on: 05 April 2012, 10:51:44 am »
Thanks I'll have a look
Z
mcyoungy
« Reply #4 on: 05 April 2012, 11:01:24 am »
Genuine chain is £50 from Yamaha. Wemoto sell a DID for £60.
Are you sure it's the chain and not the tensioner? It's normally these that cause noise. They're £140 genuine. You'll need gaskets too - a few quid.
Fitting the chain isn't a tough job but you'll need to remove the tensioner and at least one cam sprocket.
If it's only a bit noisy does it really need changing? Best to check the wear limit before you tear into it.
zarniwoop
« Reply #5 on: 05 April 2012, 11:23:02 am »
Thanks kebab
http://fazerowners.yuku.com/topic/32904/New-tensioner-installed?page=1
A V useful post
mcyoungy
I keep thinking about doing it myselt
It's not a job I've done before
not made my mind up yet
cheers
Z
« Reply #6 on: 05 April 2012, 09:02:13 pm »
If you replace the cam chain and after removing all the necessary bits to get to it including the plugs. Check the tappats first as now is a good time to replace any shims, remove both cams but do not remove the sprockets. there is no need.
This allows you to turn the engine over to feed the new split chain through the tunnel and around the crank without destroying your valves.
Line up the exhaust cam first and then roll the inlet one back in, a little bit of trial and error and frustration if you don't get it right first time.
All cam and crank marks should line up perfectly.
The best way to check if the chain is worn is to see if the timing marks line up.  a worn chain can be up to one tooth out in the timing. The timing on my 600 was over one tooth on the exhaust side and the chain was a link and a half longer than the replacement. The tensioner was not at the max but about 5 notches from the end.
janner_10
« Reply #7 on: 06 April 2012, 05:38:59 pm »
If the rattle goes away once your warmed up - thats quite normal on the fazer - nothing to worry about - give it a few red lines - i will soon settle down.
