Date: 25-05-26  Time: 05:40 am
Author Topic: FZS 1000 2004 Model, Silver, handlebars?  (Read 2384 times)
Decoke Dave
« on: 07 August 2018, 09:21:10 pm »
The ones fitted to my bike are silver painted. Always thought they were original, am I correct
Triggergee
Re: FZS 1000 2004 Model, Silver, handlebars?
« Reply #1 on: 07 August 2018, 10:05:20 pm »
 :useless Lol if they're Renthals which seem most common then they are anodised.
If originals you can quickly check some of these things
[size=78%] slip off the throttle or left switch controls there will be a small hole in the bars maybe 4mm? to keep the controls fixed firm [/size]
[/size][size=78%]lift one of the brackets mounting it to the yolk risers and it will have notches cut into it for grip[/size]
[/size][size=78%]If you remove one of the bar ends it will look like the thread in the bars is an insert which is welded in [/size]
[/size][size=78%]There is also a number stamped on the bars at the clutch grip end although this is impractical to view[/size]
[/size][size=78%]There is likely a dot punched into the bars as a marker near the mounting point with the risers [/size]
Decoke Dave
« Reply #2 on: 22 August 2018, 04:58:28 pm »
Sorry, all I am trying to say is, on a 2004 model (1C2) were the original handlebars of a silver painted appearance from new.
Hedgetrimmer
« Reply #3 on: 22 August 2018, 05:41:39 pm »
Strangely enough, I have silver-painted ones on my 2005 lava red model, and have often wondered the same. They seem to be the same shape as black chrome/finish ones I've had on all previous ones.
« Reply #4 on: 22 August 2018, 09:21:10 pm »
Apparently they came like that. I asked that question when son bought the 1000 I have now and the original owner said they came like that as he had bought the bike new and had only ever put a givi rack and top box on it.
