Date: 25-05-26  Time: 03:59 am
Author Topic: Oops.....tricky wiring!  (Read 3452 times)
Andy W
« on: 02 August 2018, 07:24:19 pm »
Well I certainly don't make life easy for myself!  :rolleyes
Have bought a Koso DB-03R  multi-gauge......now it's out of the box I'm looking at the wiring instructions & thinking I've bitten off a very large chunk of headache pie!
Aaaargh!  :'(
celticbiker
Re: Oops.....tricky wiring!
« Reply #1 on: 03 August 2018, 07:06:23 am »
Let's have a look then.
If it doesn't look like this then you'll be fine.
Andy W
« Reply #2 on: 03 August 2018, 11:50:07 am »
Quite right, it's not as bad as your pics!
I have had a good look again this morning & the Koso wiring is simpler than it looked yesterday evening (I am sober now which may have something to do with it! :rolleyes )
Much of it is showing various ways to fit the RPM wire depending on your bike so can be ignored.
Also, I splashed out on the GPS speedo adaptor so that's an easy plug in fit!
Mind you, there are also endless pages of set-up instructions! :eek
It's the cheapest decent brand multi-gauge I could find but it's a small unit tho' so will look a bit daft replacing all the dials but I may fit the Garmin next to it to fill out the dash a bit!
Hugh Mungus
« Reply #3 on: 03 August 2018, 03:31:55 pm »
One wire at a time. Don't try to rush the job.
Draw a diagram of the wires on your bike noting the colours and what they do, then just match up the new wires. If you draw a diagram/table it will be easier to follow when connecting the wires up. It will also be very useful to keep for the future.
Andy W
« Reply #4 on: 03 August 2018, 08:00:25 pm »
Ok Gurus, I need some help please if any of you have fitted this type of thing before....
Q1/  The Koso white wire is for gear indicator, once fitted, there is a procedure you do which means the unit apparently learns your gears.
The diagram seems to imply that you just take the white wire to neg.....can that be right?
Q2/ The Koso comes with it's own screw in temp. sensor, could I not just tap into the existing sensor wire? If not, where on earth is the Fazer's temp. sensor to be found?
Q3/ What on earth is an EOBD?  :eek
Currently regretting very much buying this unit so any advice greatly appreciated!  :o :\
tommyardin
« Reply #5 on: 04 August 2018, 07:40:50 am »
EOBD :  European On-Board Diagnostic : It is a diagnostic or electrical fault finding scanner.
Andy W
« Reply #6 on: 04 August 2018, 11:04:22 am »
Thanks - does the Gen.1 have such a thing?
Andy W
« Reply #7 on: 04 August 2018, 01:40:31 pm »
Well, hopefully I'm getting there slowly....according to the supplier the EOBD wire can simply be ignored if the bike doesn't have one fitted, & the white wire just connects to the neutral dash light wire.
Fingers crossed.......... :)
