Date: 15-03-26  Time: 00:04 am
Author Topic: Performance gain from K&N air filter?  (Read 10455 times)
agricola
« on: 06 April 2018, 02:43:32 pm »
 As per the title, is there any gain to be had from K&N filter. Ima always a little wary of manufacturers claims
Dudeofrude
Re: Performance gain from K&N air filter?
« Reply #1 on: 06 April 2018, 11:11:34 pm »
In a word No, if it combined with a free flowing exhaust then you may experience a 1-2 bhp increase but that's only due to the increase air flow, which in turn will make the bike run slightly lean so that increase will only be a certainly rpms.
If the bike is currently running slightly rich then the K&N could help improve the power but other than thats its only useful when you start having it tuned that's when you start falling down the aftermarket/modding rabbit hole,
1 day your buying a free flowing air filter and 6 months down the line your trying to decide if you want your new lightweight pistons to be forged or cnc milled aluminium .... its a slippery slope haha
mtread
« Reply #2 on: 06 April 2018, 11:31:14 pm »
Makes a noticeable difference to the FZS600, but that's a carb bike that otherwise runs rich. Not sure it works for a FZ6
Slaninar
« Reply #3 on: 07 April 2018, 06:17:06 am »
Some claim noticeable gain in higher RPM (and power) range, with some loss on low revs torque. I just love and notice the sound of the open exhaust pipe.
agricola
« Reply #4 on: 07 April 2018, 04:53:59 pm »
I ve recently fitted Scorpion end cans and de-cat pipe. My understanding is that on fuel injected machines, the ecu adjusts fuel supply based on information sent to it by the O2 sensor, so aftermarker exausts/air filters are compoensated for automatically. Is that correct?
pilninggas
« Reply #5 on: 07 April 2018, 09:54:03 pm »
Only partially. The type of O2 sensor used on motorcycles is 'narrow band' and is only used when the bike is running at steady throttle [cruising along] to keep the bike as close to stoichiometric fuelling (14.7:1), it effectively gives a high-low output and does not tell the ECU the exact amount of fuel being burned. In all other conditions - closed throttle, under load, WOT etc - the ECU looks at the map in it's rom. That's the purpose of things like the power commander, they pull the map nodes in the direction required by the tuner. A 'wideband ' O2 sensor can be used to alter fuelling at all points and it's why you buy 'autotune' or similar devices [I dont rate them for motorcycles, as the response is too slow compared to the fuelling change rate].
Grahamm
  • Global Moderator
« Reply #6 on: 08 April 2018, 12:46:09 am »
Yes, they gain more of your money... :D
Gnasher
« Reply #7 on: 25 May 2018, 08:30:42 am »
On it's own nothing you'd notice, if you fit a power commander you can then remap which will clean things up for you and take away the snatchy throttle response and perhaps give you a few bhp across the rev range.  Total cost £420 odd or secondhand who knows a guess, about half if you can find them.
Not a popular up grade this or at least in my experience but for you it may be all your looking for, choice is yours.
