Date: 25-05-26  Time: 15:18 pm
Author Topic: Lost horn and right turn signal  (Read 2797 times)
Staryarm
« on: 15 February 2018, 04:27:42 pm »
So been doing some bits on the bike today and long story short a stray wire has bridged the 3 prong plug I believe is there for Yamaha alarm system and the positive on the battery.
Since this the horn and left turn signal has stopped working iv checked the flasher relay that's fine and all fuses are fine but still nothing
Re: Lost horn and right turn signal
« Reply #1 on: 15 February 2018, 05:19:33 pm »
Was the stray wire attached to your hand when this happened ?  :lol :lol
Was it just a visual check or a meter check you did, sometime they look like they are ok, but blown.
Check all the fuses as you could have blown any of these three the Backup, the Signal or the Ignition fuses.
Staryarm
« Reply #2 on: 15 February 2018, 06:09:02 pm »
Checked all fuses and bulbs and there fine. Only bulb iv not checked is the dash left turn bulb
« Reply #3 on: 16 February 2018, 05:35:12 pm »
Does the bike start and run? Are this standard indicators or LED?
The dash indicator bulbs work in parallel with the main indicator bulbs.
If standard indicators, remove the indicator relay, bridge the pins in the connector. Turn on the ignition, switch on the indicators, check if the indicator lights come on and stay on until switched off again. Check the horn also.
Staryarm
« Reply #4 on: 16 February 2018, 07:08:24 pm »
Bike starts and runs fine still riding it.
Iv got stock indicators front and led rear. Checked relay it's fine and checked everything else all I can thing is it's fried a wire somewear as it's just left turn signal and horn.
I have a few hours on it tomorrow and try find it
« Reply #5 on: 17 February 2018, 01:24:25 pm »
What happens when you press the Hazard light switch?
Staryarm
« Reply #6 on: 17 February 2018, 10:44:59 pm »
Every one except front right come on.
But if sorted the indicators now I opened the left switch gear up to check connections and looked fine put it back on and all's working haha
Just horn to sort out now
Dustydes
« Reply #7 on: 18 February 2018, 10:43:47 am »
Give horn a tap they rust up and stop working. Check the 2 connections on the horn for Voltage.
Staryarm
« Reply #8 on: 18 February 2018, 07:41:44 pm »
Swapped it for another horn all working fine now and iv relocated it to under the tank ready for when I get rid of the front end
