Date: 07-05-26  Time: 12:26 pm
Author Topic: Loose front right foot peg.  (Read 2967 times)
Mjhb
« on: 20 November 2017, 02:56:52 pm »
Hi Foccers,
The front right foot peg on my 98 Boxeye is loose, i.e. it rotates rather than wobbles up and down.
I’m sure I read somewhere that this is quite common. Is it ? Is it an easy fix if not ... or a likely MOT failure ?
Thanks in advance,
Matt
limax2
Re: Loose front right foot peg.
« Reply #1 on: 20 November 2017, 08:36:33 pm »
Should be an easy fix. The footrest is held in the aluminium bracket by a socket head bolt from the back. You will need a suitable size allen key and just tighten it up. I thought there were a couple of flats to stop it rotating, on the bit that the brake pedal pivots on, but maybe not. Either way just tighten it up with the footrest in the correct  orientation. Not good for the MOT if loose and worse if the bolt drops out completely and the footrest disappears.
tommyardin
« Reply #2 on: 20 November 2017, 09:01:30 pm »
 :eek
I once had a Honda and the handbook said that the front tyre pressure was 32 psi, well mine only had 19 psi so I sold the bike, did i act in a hasty manner   :rollin :rollin :rollin
Mjhb
« Reply #3 on: 21 November 2017, 12:35:48 pm »
Thanks Limax ... thought I’d found somewhere before that said ‘they all do that’ ... anyway, much appreciated !
Mjhb
« Reply #4 on: 21 November 2017, 12:36:43 pm »
Thanks Tommy ... will have to consult Mr Haynes’ manual more closely 😉 👍🏻
Bretty
« Reply #5 on: 22 November 2017, 10:07:51 pm »
My left peg came loose and I seem to remember it being pretty easy to tighten. There's just a screw on the back
tommyardin
« Reply #6 on: 22 November 2017, 10:52:56 pm »
Your welcome Mjhb, if I can help as I walk life's beaten path. Lol!
Some members in here used to take the piss but thankfully that's been banned. :rollin :rolleyes
There are still a couple of foccers in here to watch out for, but firstly it would be bad etiquette to name them and secondly fazersharp and hedgetrimmer would be cross with me if I named them.
Frosties
« Reply #7 on: 22 November 2017, 11:10:52 pm »
Good call - don't mention that Polish bugger Tomski either....
Disorderlypunk
« Reply #8 on: 22 November 2017, 11:15:43 pm »
how did the interview at wikileaks go ???
