Date: 17-05-26  Time: 23:43 pm
Author Topic: Jack up kit versus dropping the forks.  (Read 13566 times)
« on: 04 September 2017, 06:54:59 pm »
I wondered if anyone knew if there's a direct relationship between the height of a jack up kit as opposed to lowering the front through the yokes.For example would a 25mm jack up have the same effect as say dropping the front 5mm. Thanks in advance.
Re: Jack up kit versus dropping the forks.
« Reply #1 on: 04 September 2017, 08:35:51 pm »
It would be useful to know why you are asking the question.
For me the best option is a 25mm jack-up kit and having the yoke down the forks by ~15mm. I currently have a 50mm jack-up kit and having the front dropped at all adversely affects the handling. The 50mm kit and the forks at the OEM position gives roughly the same handling as the 25mm kit and a ~15mm drop. You could possibly infer from that that a 25mm Jack-up kit has a similar effect to having the forks dropped by ~15mm but I feel that's far too simplistic.
F4celess
« Reply #2 on: 05 September 2017, 10:56:35 am »
Any pics on the 50mm dog bones?  :eek
I'm actually about to fit 40mm ones. I was concerned 25mm would look too subtle, so added an extra 15mm to be on the safe side.  :lol
Dudeofrude
« Reply #3 on: 05 September 2017, 11:01:54 am »
I'm considering doing this too but mainly just because my seat is too low. I can flat foot with both feet and even stand up off the seat slightly. Didn't really think about the handling differences it might make 🤔
F4celess
« Reply #4 on: 05 September 2017, 11:17:01 am »
Yes, cosmetics is one reason, plus I'm tall and feel like I'm sitting ONTO a chopper sometimes lol. After putting one leg over and sitting down, feels like my head height has dropped about a foot.
High speed stability is affected apparently, by raising the rear on dogbones (obviously magnified the higher you go)... don't know exactly how that will manifest itself, don't want to be in a situation where it happens either!  :eek
« Reply #5 on: 05 September 2017, 11:37:10 am »
Having read Falcon's post regarding changing his usds back to right way up forks because of Spanish MOT bureaucracy, I noted that he'd dropped the forks through the yokes by 12mm. I currently run a 25mm jack up, but as I have the GYT-R bar lowering risers, the space between the fork top and underside of the handlebars is a bit limited but not impossible to drop the forks through. Just wondered how "radical" the 25mm lift was in comparison to dropping the front 12mm, and if the 25mm only equated to say only a 5mm fork drop, then 50mm dog bones would be the way to go.
Dustydes
« Reply #6 on: 05 September 2017, 02:01:51 pm »
Ive gone 25mm at back 12mm at front with adjustable dogs. Great mod turns so much better. You sit with weight forward into tank instead of rocking back when hard on throttle so more stable acceleration. Front stays more planted and turns into a corner much much better. Shakes her head a small bit on hard acceleration but never has got frightening even with the full monty.
Go for it its not something that cant be reversed easily or will cost you a fortune.
You can make dogs out of flat bar with a couple of holes in, you don't need to shape, that's the way I went first time after R6 shock.
http://www.yamahafz1oa.com/forum/showthread.php?t=132112&highlight=dog+bones
« Reply #7 on: 05 September 2017, 05:30:39 pm »
One I took last week, you can see the rear wheel is pretty much on the ground but both stands are still usable though I avoid the side stand where I can, the tail is about waist height (6'3").
« Reply #8 on: 05 September 2017, 05:34:41 pm »
I'm 6'3" with an inside leg of 33" with the 50mm Jack up and my Nitron shock on maximum ride height the bike looks and feels the right size for me, I've never experienced high speed stability issues.
« Reply #9 on: 05 September 2017, 05:39:02 pm »
I have the GYT-R risers and Renthal 758's the lack of clearance for dropping the yokes was the main reason I went with the 50mm jack-up kit, the other was I wanted the bike to be taller to fit me better.
« Reply #10 on: 05 September 2017, 06:18:54 pm »
Does that mean you can't rotate the rear wheel for chain lubing. The sidestand wouldn't be an issue as am already using a lengthened one. Yours certainly looks the business and a great location for the pic. too.
« Reply #11 on: 05 September 2017, 07:49:52 pm »
I can turn the rear wheel as long as the floor is level otherwise it can catch, bare in mind that I also have the ride height adjuster on my shock set to max height so I don't think it will be an issue.
« Reply #12 on: 05 September 2017, 07:56:26 pm »
Ok, thanks for your input and advice.Very helpful :thumbup .
F4celess
« Reply #13 on: 06 September 2017, 09:16:25 am »
Lovely Harrier!  :lol  ...the Bike is looking sweet as well. Doesn't look "extreme" on 50mm.
Definitely a Tail up look, but not over the top. Very sporty.
After finishing the 40mm Links last night (no mods on the front forks), the rear wheel is on the ground, with the centre stand down.
Infact the bike 'rolls' back onto the centre stand much easier, with less jolt, as the rear wheel stays in contact with the ground.
Riding the bike today, DOES feel lovely around the corners, no nasty surprises, plus under hard acceleration (as was said above) there's less tendency for you to be rocked back on the seat, as you are angled more forward. Legs feel much more natural too now, with the longer reach with the ground.
5LV
« Reply #14 on: 06 September 2017, 10:26:58 am »
changing the length of the dog bones also changes the rate of compression of the rear shock. iirc it softens it up if you lengthen them.
so not only do you have to be concerned about ride height, but also spring rate and damping.
dropping the forks just changes the weight distribution and steering qualities.
there's a good reason why firms like k tech, maxton are in business.
« Reply #15 on: 06 September 2017, 01:48:58 pm »
there's a good reason where y firms like k tech, maxton are in business.
You are correct but maybe not in the way you think. A jack-up kit uses shorter dogbones firming up the rear which is highly beneficial if you are still running the weak OEM shock, if you are running a decent aftermarket shock you can adjust it to compensate if necessary.
Dustydes
« Reply #16 on: 06 September 2017, 02:13:02 pm »
Any changes to geometry of bike and suspension should be checked and adjusted as PieEater said.
I will be going R1 with K Tech soon which will be 35mm lower at front and will be fitting a Hyperpro rear shock instead of the R6 (which is a great mod) so expect a lot of changes to be made.
I also have Gilles so can adjust my leg position.
Next summer I plan on having suspension set up by a pro, for about £50. I think its worth it.
Dudeofrude
« Reply #17 on: 06 September 2017, 04:04:34 pm »
Theres a good reason companies like Yamaha are in business. Afterall they put the stock shock in there in the first place. They spend hundreds of thousands in R&D and have teams of specialists design and set up a motorbike to work exactly as it should.
Then the average joe whos buys it decides it's not good enough and changes parts out for something they deem to be 'better'
« Reply #18 on: 06 September 2017, 10:26:30 pm »
I think that all mass produced bikes and cars are built to a price, and in the case of bikes, suspension and sometimes tyres are both areas where money is saved, unless you're buying something a bit up market that comes with eg ohlins. Stock suspension does it's job but is the area that in most cases can be greatly improved with aftermarket units/parts.
slappy
« Reply #19 on: 06 September 2017, 11:02:03 pm »
The manufacturers make the bikes to fit a very large one size fits all market, and to be safe. The bike has to suit people of vastly different weights, height, leg length, arm length etc, and all this has to be done within a certain price bracket to ensure sales and profit.
5LV
« Reply #20 on: 07 September 2017, 08:07:55 am »
the reason maxton et al are in business are because firms like yamaha get it wrong so often. why else would they sell a fazer with a spring rate set for 10st.
dynojet had a record year in 2006/7 sorting out the fz1 fuelling.
would you like some savlon for those burns
Dudeofrude
« Reply #21 on: 07 September 2017, 08:19:51 am »
Maybe because the vast majority of Yamaha customers around the world aren't all fat bastards like us in the UK haha and while I'll agree that they royally fucked up in 2006 with the Fazer fuelling they sorted it out by 2008 negating the need for dynojet to do anything unless people start messing with the bike again.
Look I'm on your side in all this, my bike is more heavily modified than most but I still stand by the fact that if you left the bike completely stock it would run/ride better than 90% of people could actually ride it. The problems only start when people do 'mods' for the sake of doing mods
A prime example being swapping the exhaust out for something louder/prettier which straight away messes with the fuelling which then leads on to buying a power commander then a remap and changing air filters etc etc.... where as if ya left the pipe alone the bike wouldnt have sounded as cool but would have been running fine
« Reply #22 on: 07 September 2017, 09:04:24 am »
FFS Dudeo how tall are you? Flat foot both sides and still manage arse off seat.
I'm 5' 9.5" and can almost stand up under the centre stand.  :rollin
Dudeofrude
« Reply #23 on: 07 September 2017, 09:24:09 am »
Only 6' 2 but quite long legged haha
NorthWestern
« Reply #24 on: 28 September 2017, 06:07:41 pm »
I wrote an app for my phone for bike setup (geometry) that allows you to alter pretty much anything and see the effects visually and with compression graphs on the rear shock etc you can compress the suspension and see the links working...  if anyone can be bothered taking the measurements of the fazer it would give you the answers your looking for :)
