Date: 19-04-26  Time: 18:35 pm
Author Topic: Quick action throttle  (Read 3969 times)
fireblake
« on: 19 June 2017, 08:21:10 am »
I've been having a bit of a problem with my wrist and was wondering if any of you guys use a quick action throttle on their Thou' and does it make for an easier ride?
Thanks,. Mickey
BBROWN1664
Re: Quick action throttle
« Reply #1 on: 19 June 2017, 12:12:36 pm »
Nt used one but I would have thought it made for a harder ride as throttle inputs would be magnified so not as easy to apply small changes
Gaz66
« Reply #2 on: 19 June 2017, 07:53:31 pm »
Quick action throttles tend to pull a lot of cable per degree of rotation, so might be a bit aggressive on a "Thou"?...Perfectly fine on a track bike but a rd bike needs a bit more throttle finesse.
Apparently an R6 throttle tube has a larger cable drum, hence pulls more cable than a standard Gen 1 "Thou" throttle tube, not as aggressive as a full on quick action but better than a "Thou" (apparently) ?
I'm considering getting one for mine.
Not sure if throttle housing will need some mods but it's been done before so i guess all the info is on web somewhere.
Cheap enough new, loads on Fleabay.
Rgds
Gaz
fireblake
« Reply #3 on: 19 June 2017, 08:01:42 pm »
Rgds
Gaz
Interesting. I have small hands and bad wrist pains from a few broken wrists as a kid so a shorter action would suit me. I suppose the aggressiveness could be tuned out with getting used to it like most things. I'll have to look into the R6 option. Thanks
Mickey
b1k3rdude
« Reply #4 on: 19 June 2017, 08:15:23 pm »
Would having large grips (as in heated grips, off in this weather obviously) but it make it much easier I have found to turn the throttle
fireblake
« Reply #5 on: 19 June 2017, 08:22:22 pm »
That's another good idea
Mickey
slimwilly
« Reply #6 on: 05 July 2017, 07:28:31 am »
R6 tube on mine, works very well, gen 2, all the worries of jerkiness, harsh action is utter rubish
fireblake
« Reply #7 on: 05 July 2017, 11:46:33 am »
Thanks Slim, do you think this would work OK on a Gen1? Is it just a change the part mod. One for one?
Mickey
old son
« Reply #8 on: 05 July 2017, 12:17:36 pm »
I fitted one to a ZX10R which was ridden on the road 99% of the time. You soon get used to the throttle and it was very easy to ride. I would do it if I were you.
slimwilly
« Reply #9 on: 06 July 2017, 07:45:46 am »
Mickey
Not sure mate, demote I think , £10,
