Date: 08-05-26  Time: 00:47 am
Author Topic: Loosing power ???  (Read 8811 times)
Fazer99
Loosing power ???
« on: 27 May 2017, 06:15:20 pm »
Hi all,
On my way home from work on Thursday my red beast started playing up, it's getting to about 60mph at about 6/7k and the engine is straining as I'm pulling the throttle and the noise from the exhaust is like that noise when you let go of a balloon. I thought it might be crap or a bit of water in the fuel so I've flushed it through with fuel cleaner and also given the carbs a good blasting with carb cleaning spray, the air filter is clean and there is no pinching to the fuel pipes, I also checked the spark plugs and they look fine but I'm still getting the problem, as I'm no mechanic I'm at the end of any ideas that I think it might be so any help or advice is very much appreciated and needed 😁👍
I was thinking that maybe there is something stuck in the exhaust but then surly if there was wouldn't that noise and straining happen from the start rather than just at higher speeds?
Also something I just noticed today as I was working on it that the rev counter when trying to simulate the issue while on the paddock stand would go a bit crazy just after the straining starts happening so could it be an electrical fault or could that just be due to the engine struggling causing the counter to not be able to read properly and just confusing the system?
Re: Loosing power ???
« Reply #1 on: 27 May 2017, 06:49:57 pm »
Maybe a blocked or kinked breather pipe under the tank?
If it happens again open the fuel cap and see if it gasps for air, or just check the pipes are routed correctly and not folded at all.
« Reply #2 on: 27 May 2017, 06:51:02 pm »
Sorry, just seen you've checked that.
« Reply #3 on: 27 May 2017, 06:52:55 pm »
Is your TPS okay, do a check on that as that makes the rev counter go loopy if it's knackered, and the general running of the bike will feel ropey.
Fazer99
« Reply #4 on: 27 May 2017, 07:33:10 pm »
Where would I find that and how do I check it
Fazer99
« Reply #5 on: 27 May 2017, 08:13:48 pm »
Just checking through my Haynes manual and the TPS was what I thought it was and where I thought was  :D  now just trying to work out how to check it
« Reply #6 on: 27 May 2017, 09:22:21 pm »
The TPS outer case unplugs, it's a bit fiddly, i normally gently use a flat key to unhook it.
With key in ignition switch it on (don't start engine).
Unplug the TPS
The rev counter needle should go to 3000rpm.
Then plug it back in and the needle, if positioned correctly should land on the 5000rpm mark.
If it goes to 0rpm or 10,000rpm it needs adjusting back to 5000rpm.
If it goes to 3000rpm it's totally knackered.
To adjust it the 2 screws need slackening with a security torx allen key, then rotate the TPS unit until it lands on the 5000rpm spot.
Be aware, these units can slowly break down rather than just stop working so can misbehave for a while until you realize it needs replacing.
Fazer99
« Reply #7 on: 27 May 2017, 09:39:37 pm »
Cheers buddy, I was struggling to understand what my Haynes manual was going on about  :lol  it doesn't help as they mix 2 different bikes into each chapter.
« Reply #8 on: 27 May 2017, 09:42:27 pm »
You need a torx allen key size T25, but the tamper proof type with the hole in the middle of it, to go over the pin in the centre of the screws.
Fazer99
« Reply #9 on: 27 May 2017, 10:02:50 pm »
I've got a few T25 Torx Allen bits but not security ones so I might try drilling a little hole in one of them so it will fit.
Looks like my Sunday is going to be another day in the garage 😁
« Reply #10 on: 27 May 2017, 10:25:19 pm »
Whole process only actually takes minutes to do.
I've had 3 TPS' fail on me, but the 2nd & 3rd were used ones, so years old.
4th one was brand new, think it cost around £70.
So if you think you need to replace it buy new, as a used one will be at least 14 years old and about to peg out as well.
Usual signs, other than the RPM needle are rough/erratic running, most noticeable at under 3000rpm, the bike becomes jerky and not smooth at all.
Fazer99
« Reply #11 on: 27 May 2017, 11:02:55 pm »
Where did you get the new TPS from? as I tried searching on wemoto where I get most of my parts from but no results there.
« Reply #12 on: 27 May 2017, 11:28:03 pm »
Ebay - "throttle position sensor FZS600"
Fazer99
« Reply #13 on: 27 May 2017, 11:48:55 pm »
Cheers buddy I didn't think about evilbay  :evil  everywhere that was showing results using google were asking for near the £200 mark so I started to crap myself worrying that this could be a chuffing expensive repair.
« Reply #14 on: 27 May 2017, 11:51:11 pm »
If I was you I'd start by trying to figure out if it's a problem with one cylinder or all of them. I'd run the bike in the rev range where it's losing power and then throw some water on the headers and check to see if one of them dries slower than the others. If one does dry slower it'd point to that cylinder having the problem and you could try swapping parts from that weaker cylinder onto a good cylinder. Do it one part at a time. Plug caps and coils are common culprits. If you throw water on the headers and they all dry at the same rate then you know it's a problem with a part that effects all cylinders so fuel supply, tank, fuel filter, pump, carbs, air filter, tps, maybe reg/rec. What did the plugs look like when you took them out?
Fazer99
« Reply #15 on: 28 May 2017, 12:13:01 am »
All 4 cylinders are firing as I did test them just as you stated, plugs looked good slight burnt residue as to be exspected and the plugs and leads were only just changed a few months ago. I had been checking through the mechanical side of things to the best of my mechanical knowledge as I know less about electronics than I do about mechanics  :lol  fuel lines are flowing fine as I connected up some clear piping that I had and you can see the petrol getting sucked through with no gaps. From what darrsi has said and from what I've read in general online it does sound like a faulty TPS is a strong culprit, but don't worry I will be testing before I buy a new one as I'm not spending money on something I don't need 😁
maxzer1500
« Reply #16 on: 28 May 2017, 08:58:44 am »
[/quote
    You can simply use a punch or similar to snap off the central pin and use the Torx bit as is.]
Fazer99
« Reply #17 on: 28 May 2017, 09:58:16 am »
didn't think of that as I thought they were designed to be strong enough to not be tampered with in that way.
« Reply #18 on: 28 May 2017, 10:17:24 am »
You would by the security torx bit for for about a fiver  :rolleyes
« Reply #19 on: 28 May 2017, 10:19:09 am »
I wouldn't go down that route if truth be told, that might not end too well.
Word of warning as well, if the needle hits 10,000rpm, DON'T TURN THE IGNITION OFF.
The needle will be be leaning to the right and gravity will simply make it drop clockwise.
Then you"ll have to take the clocks apart to move it back round to zero.
Just start the engine and it will move back itself to the correct side.
« Reply #20 on: 28 May 2017, 11:03:16 am »
Before you start, playing with the TPS.
Check the simple first, lack of power in the mid to upper rev range could be several things: -
1. Lack of fuel weak mixture
2. Lack of air rich mixture
3. Too much air weak mixture
4. Too much fuel rich mixture
5. Weak spark.
The ignition system on Fazers is pretty solid, the leads can fail as can the caps and where the leads join the coils, or a cracked plug.  All of these are easily checked, inspect the leads/caps and plugs, if all cylinders are firing it's suggesting your issue isn't the ignition system, but it could be.  Lift the tank start the bike close the garage door just enough to darken the garage DONT shut the door, don't go mad or stay in there too long, it takes minutes to do this. If you don't have a garage do it at night outside, rev the bike and look for arching across the caps/leads.  You normally suffer poor starting with ignition system problems, which you don't mention so I assume haven't got?
Based on the information you supplied I'm doubtful it's an ignition problem.
You've checked the breathers and you say they're ok.  This leaves fuelling and air as likely culprits, check in this order: -
1. Air blockage, check the air intake I've seen rag or neck warmers sucked into the intake which restricts the air flow in mid range riching up the mixture.
2. Check the filter they don't last for ever, this is easy just take it out and ride it, if it all ok fit a new one.
3. Check the starter plungers are fully returning on every crab when you release the choke, this has the same effect as above.
4. Check the carb diaphragms even a tiny hole will stop a slide from raising, this will give you a weak mixture.
5. Check the inlet rubber balance nipple caps these split/tear when being pulled off, sucking in air and weakening the mixture.  The inlets rubber will crack but these are very rarely more than skin deep, often owners waste money replacing them for nothing.
6. Check the fuel line, start at the petcock the clean the filter, check the inline filter and check the pump run a pump test.
In my experience it's very rarely the ignition system but could be caps leads are the main areas to check, I've never had a TPS actually cause your issue, when they fail the bike just doesn't run as well.  The same with carbs being out of balance they just don't all of a sudden go out of balance and unless they way out the bike will still pull in the upper rev range just not as well.
Good luck lets us know how you get on.
Fazer99
« Reply #21 on: 28 May 2017, 12:07:59 pm »
TPS was out as so I adjusted. Problem still there. Just had a mate pop over who heard the problem I was having and he thinks it would be worth changing the plugs and air filter as they are at the mileage range where they should be changed and although the plugs look fine they may well be breaking down especially as at higher revs where the problem is, he also pointed out that the air filter is not as clean as I thought it was. So going to order those parts and if still no joy I'll go through what you have listed to check Gnasher.
Thanks for all the help and advice, I'm calling it a day as it's getting on my tits plus I can't do anything until I get the parts. I'll keep you all posted on the progress 😁👍
« Reply #22 on: 28 May 2017, 02:46:20 pm »
TPS should read 5K.
If it reads 0 or 10K it needs adjusting
Fazer99
« Reply #23 on: 28 May 2017, 03:02:05 pm »
TPS should read 5K.
It was showing 10k but I have now adjusted it so it's reading 5k but the problem is still there, I've just ordered a service kit for about £50 from wemoto that contains all new air filter, oil filter, fuel filter, 4 spark plugs and sump plug washer. It was cheaper to do that rather than just buy plugs & air filter as I would need to buy the oil filter stuff later on any way for when I do the next oil change.
« Reply #24 on: 28 May 2017, 09:35:09 pm »
As i said before, from previous personal experience the TPS rarely just stops working, they break down.
As you know how quick and easy it is to do now, check it again at the end of the week, and see if it's still sitting at 5k, if it isn't then it's time for a new one.
They quite obviously have a tendency to become faulty over time so it would be no surprise to me if it was knackered.
I've learned the signs now by the behaviour of my bike because of how many i've changed, but the new one sorted it all out.
