Date: 19-04-26  Time: 13:03 pm
Author Topic: Chain and sprocket  (Read 4599 times)
kitcrazy
Chain and sprocket
« on: 19 May 2017, 10:53:05 am »
Recommendations for new chain and sprocket please standard gearing.
moffmeister
  • Global Moderator
Re: Chain and sprocket
« Reply #1 on: 19 May 2017, 10:59:14 am »
have always got mine from bandcexpress.co.uk
...but I'm currently downgeared on an AFAM 1down,1up setup from Bike Torque Racing with DID Gold Super X Ring Chain from urbanbikeshop on Ebay - both  quick delivery
« Reply #3 on: 19 May 2017, 03:02:58 pm »
Check out bumbanditbondage.com tell them exupnut recommended them and you want to try out their range of chains. Good luck.  :D
cl1ve2004
« Reply #4 on: 19 May 2017, 03:28:42 pm »
put ognibene quiet sprockets and DID Xring 530Zvmx endless chain £160 the lot..(i had to overhaul swingarm so got the endless chain)
kitcrazy
« Reply #5 on: 20 May 2017, 10:56:58 am »
Check out bumbanditbondage.com tell them exupnut recommended them and you want to try out their range of chains. Good luck.  [/size]                      pmsl 😂😨
topgun44
« Reply #6 on: 20 May 2017, 06:00:26 pm »
DID chain  and JT sprockets all the way
celticbiker
« Reply #7 on: 28 May 2017, 08:13:58 am »
You will always get a million different answers to this question.
Fwiw the fact is that like tyres and brake pads you should always buy the best you can afford.
TBH most people should never have to replace a c&s set these days.
I personally buy individual parts a they can often be got cheaper that way. Search eBay for the size and length of chain you want rather than for your bike and also cross reference your sprockets with other bikes too, my fazer 8 used the fitment rear  sprocket and exactly the same front sprocket as my tdm (same brake pads too)
As for what brand you should buy, well, to some extent it depends on your use of the bike.
If you're a weekend warrior then an o ring chain and JT sprockets will be fine but I'd you do more regular riding them an x-ring chain with afam sprockets.
If you are a high mileage rider like me (25000 miles/year) I would suggest DID X-RING chain and renthal sprockets.
I get around 35000 miles from a set with a scottoiler.
Ultimately though I guess money is king here as none of them are cheap.
Simon.Pieman
« Reply #8 on: 28 May 2017, 11:26:02 am »
You neglected to mention that the chain needs to be ZVM rated, all chains of this type (new stock) are X ring anyway and usually north of £150 to buy. Anything that costs less than that is probably not ZVM.
 I fit the above with Renthal sprocket at the rear and Yamaha standard front sprocket (quieter than a Renthal front sprocket). Chain and rear sprocket lasts me about 35 to 40,000 miles when I usually find some links starting to gaul up, I change the front for a new at 15,000 (visible wear by then). I use old engine oil for lube -very sparingly, maybe a teaspoon full applied with a small paintbrush every hundred miles or so.
celticbiker
« Reply #9 on: 28 May 2017, 12:01:45 pm »
I've always used the VXGB chain <£68
http://www.ebay.co.uk/itm/192027113848?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and
Front sprocket<£18
http://www.ebay.co.uk/itm/361180081167?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Rear sprocket <£38
http://www.ebay.co.uk/itm/351915322021?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I've never had a renthal sprocket wear (front or rear) to a point that it needs changing before the chain but if quite is that important to you then it's understandable why you'd do this.  :b
Never bought an OEM sprocket, aren't they about £40?
Lube every 100 miles, good grief, I'd have to stop on the way home every day to do that  :lol
Simon.Pieman
« Reply #10 on: 28 May 2017, 03:02:33 pm »
and
Front sprocket<£18
Rear sprocket <£38
Well, it was important to me because it shows signs of wear at that mileage, after 15,000 miles that's not unusual on a superbike. A new sprocket helps my chain manage another 15,000 or so.
The OE front sprocket is £50 odd, it comes with a vibration damper that eliminates the Catherine wheel noise you get from an undamped pattern sprocket, simply a personal preference.
The chain you link to in your post is not for an FZS1000.
celticbiker
« Reply #11 on: 28 May 2017, 04:55:13 pm »
No not for a thou it's all for an 8 was just an example of what I use/pay for quality parts. They can be had cheaper than buying a kit with with lower quality JT sprockets.
VNA - BMW Wank
« Reply #12 on: 31 May 2017, 11:23:44 am »
The OE chain for the gen1 FZS1000 is DID ZVM
ZVM is not cheap.
