Date: 02-05-26  Time: 04:47 am
Author Topic: Another Stripped Counter shaft :(  (Read 11027 times)
Drezza
Re: Another Stripped Counter shaft :(
« Reply #25 on: 13 May 2017, 01:53:05 pm »
So... I've just tried the Cobalt bit and it won't touch it either!
How the hell did you do it? Feeling like a might need some sort of diamond tipped bit now  :lol
« Reply #26 on: 13 May 2017, 02:15:22 pm »
Not having to drill it myself but also wondered when people have drilled out studs and so on where do they get the high quality drill bits from and what is a high quality drill bit - not one from Wilkinsons I expect
« Reply #27 on: 13 May 2017, 02:27:28 pm »
Also depends what power drill your using aswell......you want lots of power but a slow speed....bit like a blue thou   :lol
daviee
  • Guest
« Reply #28 on: 13 May 2017, 02:31:55 pm »
could try a tile drill to  start it the are  industrial  diamond once you break through then us the cobalt
Drezza
« Reply #29 on: 13 May 2017, 02:39:36 pm »
I'm using a Heller (German) Cobalt bit, so would have thought the quality would be fine?
http://www.ebay.co.uk/itm/191884884799?_trksid=p2057872.m2749.l2648&var=490991673100&ssPageName=STRK%3AMEBIDX%3AIT
However I am using a 12v hand drill which is possibly not the best? Would have though a drill is a drill, as long as it turns what more can it do  :\
I'm very tempted to put some lock-wire through the holes of the circlip and leave it at that at this point  :lol
« Reply #30 on: 13 May 2017, 02:58:35 pm »
Ive got those I have this set - http://www.toolstation.com/shop/p94153?table=no
My problen when drilling anything other that wood is that they are all blunt now.----------- Next question
(I will start a new thread in the general section as not to de-rail this one )
Drezza
« Reply #31 on: 22 May 2017, 07:20:58 pm »
Managed to drill the hole 5mm diameter 22mm deep, had to use carbide drill bits in the end, cobalt were useless!
Now I've tried tapping the hole and having no luck again, the taps are HSS to I've got a feeling I'd need carbide taps too (if they even exist??)...
How on earth did you do it Unfazed??
Bretty
« Reply #32 on: 22 May 2017, 11:24:57 pm »
I've no idea what to suggest mate as I've never done this. Although I don't think I've ever found a metal so hard that a tapered tap won't cut it?!
« Reply #33 on: 23 May 2017, 08:52:40 am »
You will need to ensure they are tapered taps as Drezza said. I got very high quality tapered taps from a local tool shop. I will check this evening as to what type/make they are.
Drezza
« Reply #34 on: 23 May 2017, 08:58:58 am »
Fantastic, thanks Unfazed. Would be a shame to have to weld it now I've done half the work.
I thought about filing away the entrance to the hole so the threads don't start on the case hardened part of the shaft.
Bretty - I've been doing some research and it seems standard taps are only designed for use in metals with a hardness of up to 45HRC, whereas I think this shaft is about 60HRC to a depth of 1.5mm if it's case hardened.
« Reply #35 on: 23 May 2017, 09:42:44 pm »
The taps I used were "Apex UK High Speed Steel Ground Thread Tap" M6 x1
If you cannot get them let me know.
Drezza
« Reply #36 on: 23 May 2017, 10:52:58 pm »
Thanks Unfazed, will try to find some :)
I've just looked up tap sizes for 5mm diameter holes, and it appears for an m6 tap, you need a 5.2mm hole. I'm wondering if this is the issue since I'm trying to tap a 5mm hole.
« Reply #37 on: 23 May 2017, 11:27:57 pm »
Don't think it would make much difference and it was a 5mm HSS bit I used.
The tap was an intermediate taper one.
Drezza
« Reply #38 on: 24 May 2017, 03:16:56 pm »
Tried again with the intermediate tap and it worked a charm! Cheers Unfazed, lifesaver....
Done about 20 miles on it and nothings fallen off yet (touch wood), so just in time for summer.  :D
« Reply #39 on: 24 May 2017, 04:50:57 pm »
 :thumbup
