Date: 15-05-26  Time: 09:57 am
Author Topic: projector lights wiring  (Read 2025 times)
Ferky
« on: 27 February 2017, 03:21:03 pm »
 I have got a set of projectors from retrofit labs , the lights are installed into the light housing and I was going to get the extensive wiring loom fitted to the bike until I came a cross a potential problem , as some of you may know the connectors that come with the wiring loom are of the wrong type my problem is that a previous owner has been at the wiring loom on the bike , the current headlight are both h4 bulbs and are wired to work as they should but when I took the front fairing off I found another pair of wires just hanging around taped up doing nothing , these wires are black and blue/black same as the wires on the left hand headlight and after checking them they are live with the headlight switch so I am stuck with which wires actually fit to the new projector fittings . thanks for reading any help would be appreciated .
Bimbam
Re: projector lights wiring
« Reply #1 on: 27 February 2017, 06:58:30 pm »
