Date: 27-05-26  Time: 10:07 am
Author Topic: thicker sprocket nut worth a check  (Read 29361 times)
midden
« on: 28 January 2017, 01:52:44 pm »
Been experiencing grinding sounds in the chain department and a quiet knock on corners; thinking it related to the winter road crap and salt (how much lube do I have to throw  at this not year old chain ffs) I figure a clean is in order.
Removed the front cover, loads of crap around the front sprocket so the scoop out begins and suddenly once enough crud is removed to my horror the the sprocket wobbles.
The new wider nut has come off. I found the lock washer down below which had been bent round the nut as required
but some how flattened off.
I replaced the chain and sprocket in May, torqued correctly (imo) to the spec suggested for wider  nut.
tommyardin
Re: thicker sprocket nut worth a check
« Reply #1 on: 28 January 2017, 03:55:02 pm »
I have heard that some folk are only tightening the nut up to 75Nm to 80Nm, Yamaha are recommending 90Nm with the new 12mm nut, and fit a new tab washer at the same time.
Yamaha are also recommending the use of Loctite, ensuring the new nut and the thread on the output shaft are thoroughly cleaned before applying Loctite and tightening up to 90Nm.
Bending the tab washer over 2 of the 12mm nut flats
The original torque was 70 Nm with the 9mm nut, and guys are worried that 90Nm will strip their output shaft threads.
I did not have Loctite but mine went up to the recommended 90Nm and I used nail varnish on the nut and thread in place of Loctite.
Have you ever tried to unscrew the top of a nail varnish bottle for the Mrs or G/F when it had nail varnish left on the thread of the bottle top, it's often pliers on the top and smashing the top to bits in the process.
I'm guessing if you go your own way with your own ideas when it comes to tightening the nut up there really is no come back, but saying that I used nail varnish/polish not Loctite, so be it on my own head.
Quick edit:
Ensure that the cut outs on the tab washer are pushed right into the clean splines of the output shaft if they are not the tab washer can spin with the nut and not be lined up with the splines then the tab washer will do absolutely nothing.
It's best to remove the front sprocket and clean thoroughly behind the sprocket and the sprocket itself otherwise you might just be tightening up on shit, and not have a face to face metal to metal contact to torque up to.
midden
« Reply #2 on: 28 January 2017, 04:08:54 pm »
Oh well if fitted properly no problem then.
Cheers for reply Tommy  ;)
Luckily I hoarded the original nut so will get me out of trouble until new one arrives
daviee
  • Guest
« Reply #3 on: 28 January 2017, 04:11:16 pm »
Quick edit:
all good advice what i would say is it couldnt have torqued properly and the lock washer couldnt have been on right to cause it to come off
midden
« Reply #4 on: 28 January 2017, 04:25:42 pm »
Yes agree good advice Daviee.  Something was clearly amiss,  there isn't much shaft left for the tab washer to sit.
Perhaps I did fit it wrong even following instructions.
That said, my original nut never came loose so perhaps there was never a problem other than the Yamaha mechanic fitted some nuts incorrectly ;)
Kenbob
« Reply #5 on: 28 January 2017, 06:13:51 pm »
And this is proof that it doesn't' matter how big your nuts are. :rolleyes
Frosties
« Reply #6 on: 28 January 2017, 08:06:07 pm »
Also agree it's good advice from Tomski  :look  ...................................it's a bloody first for him but at least it's a start  :lol .
tommyardin
« Reply #7 on: 28 January 2017, 08:17:21 pm »
 :kiss LOL
tommyardin
« Reply #8 on: 28 January 2017, 08:18:33 pm »
Oy! Foc off Tiger :eek
Frosties
« Reply #9 on: 28 January 2017, 08:36:20 pm »
 :lol
tommyardin
« Reply #10 on: 28 January 2017, 08:40:00 pm »
A bit different from wind surfing  :rolleyes
tommyardin
« Reply #11 on: 28 January 2017, 08:46:08 pm »
Quick edit:
Daviee when you retrieved the Tab Washer after it had come off, were the sides still bent up in the locked position? if they were then I think the washer was never located properly.
midden
« Reply #12 on: 28 January 2017, 10:02:25 pm »
Good advise but presumes the nut hadn't been fitted that way.
 I just posted incase it wasn't merely my cock up.
I'll  know not to waste thread space in future  😀
tommyardin
« Reply #13 on: 28 January 2017, 10:22:18 pm »
Edit:     Midden when you retrieved the Tab Washer after it had come off, were the sides still bent up in the locked position? if they were then I think the washer was never located properly.
« Reply #14 on: 29 January 2017, 12:19:38 pm »
Nail varnish as a thread lock - it may work but I would of thought that it is too brittle whereas the locktite I believe has bit of elasticity with it.
I have some blue locktite but that is not the recommended one  read it all here     http://foc-u.co.uk/index.php?topic=14924.0
The recommended one is 620 and is very expensive
tommyardin
« Reply #15 on: 29 January 2017, 01:54:51 pm »
Cheers Sharpie,
I just read the posts in the link you put up.
So many people are saying don't tighten the nut up to 90Nm and don't use Loctite, how come so many guys know so much more that Yamaha do about a piece of machinery that Yamaha designed and produced.
It seems the Butcher The Baker and The Candlestick makers are all qualified to help you fuck up you motorcycle, by giving you their knowledgeable and poor thought out opinions and reasons.
I think I will listen to Yamaha and their expert advice and give Brian who works in the kitchen department at B&Q a miss.
If I want to know about kitchen taps I will ask Brian, because Yamaha know fuck all about kitchen taps.
I have a new front sprocket to go on my old girl in the next week or so, I have also purchased some Loctite, as I also have not followed Yamaha's advice, because i used nail varnish instead of the proper stuff.
Cleanliness is a thing to remember when fitting the sprocket nut, make sure everything in contact with the nut, washer, sprocket and gearbox face is clean and tighten it up to the recommended torque using the recommended Loctite 620, also check and re-check again that the tab washer is indeed located in the output shaft splines, and double flat the the sides of the tab washer against the nut with a tight snug fit.
http://www.ebay.co.uk/itm/122034038914
Loctite 620 is pricey (See Link above)
I would be a little hesitant about buying this stuff from Hong Kong or China.
Some of the sales of the stuff on evilBay look like they are being sent from Australia as the prices are marked up in Aus $ dollars, but with a closer look they are being posted from China or Hong Kong, seems a bit deceitful to me.
I know there is no real 100% sure-fire way of knowing that you are getting the real stuff, as there is so much fake stuff out their, ranging from Motor products to shampoo.
There is an old saying 'If a deal seems to good to be true>>>>> blah blah blah'
The link above are UK based Seller, their feedback is good and their price seems about normal.
The first picture is ideal, the second picture is a No No, because it will allow the nut to rock/rotate under the immense power of the drive and will slowly hammer the washer flats back down as it snatches as the power goes on, the other thing is use the proper washer and not a bit of thick grey paper like I used. :lol
« Reply #16 on: 29 January 2017, 04:35:17 pm »
Actually at £10 its not that expensive (wonder how long it keeps after opening) I cant see myself using it for anything else.
Your cardboard tab picture is a good guide that explains the difference between a full fold up.Just a little thing you have your cardboard tabs opposite each other but the tabs are pre creased washer are adjacent to each other.
More info on the subject here http://foc-u.co.uk/index.php/topic,9920.0.html
 http://foc-u.co.uk/index.php/topic,11851.msg130389.html#msg130389
YamFazFan
« Reply #17 on: 29 January 2017, 04:53:06 pm »
Am I correct in thinking that it wasn't the original nut and torque spec that was at fault but it was an issue with some of the output shafts being slightly undersized, thus allowing the nut to work free?.
daviee
  • Guest
« Reply #18 on: 29 January 2017, 05:06:09 pm »
another thought if you are worried about the locking washer spinning you could always tack weld it to the sprocket then it cant possibly rotate , and if your really worried you could tack weld the nut to the sprocket not the shaft then its just a case of when replacing the sprocket you would need to replace the nut aswell or in the first case the lock tab
« Reply #19 on: 29 January 2017, 05:58:32 pm »
I think I can say that the general consensus is that yes that is the case, and it is the luck of the draw if your shaft is undersized which explains why some have the issue and others not.
My own research and theory points to the first 98 models being unaffected as the shafts were done in 1 factory and then the bike took off and the shafts had to be made in other factories to keep up with demand, then there is a cut off time when the problem was spotted and after that the shafts were in spec and the 12mm nut was issued as a fix instead of swapping the shafts on affected bikes. :lurk
Over the years on this forum not 1 98 bike has had the problem --- with the caveat being that it has to of occurred on a factory fitted nut, so as to rule out a replacement not being correctly fitted. Admittedly a 98 on original sprockets is getting rare although I have one.
YamFazFan
« Reply #20 on: 29 January 2017, 06:39:44 pm »
That's interesting that no 1998 bikes seem to have been affected by this issue. Your theory sounds quite plausible.
Is the only difference in the nuts the extra couple of threads?.
 I had the uprated nut fitted to my 2003 Foxeye last year but it was done at the garage, so although I supplied the new nut (and got given the old one back) I wasn't able to compare them together.
« Reply #21 on: 29 January 2017, 08:10:43 pm »
Yes it just has an extra few threads. Maybe its the few extra threads that keeps it on but more likely its the ability to go to 90Nm that does it.
You should be able to tell if you have the deeper nut as the 9mm one finishes with just about 1 1/2 shaft thread showing and the 12mm finishes flush with the end of the shaft with no thread showing.
I have a 98 and I should add that I do trust the 9mm nut and keep an eye on it and an ear out for it and I have the 12mm nut ready to fit and will use the 12mm when I change the sprocket
More malarky here http://foc-u.co.uk/index.php/topic,19504.msg225613.html#msg225613
And here
http://foc-u.co.uk/index.php/topic,17632.0.html
I can see mine from underneath the bike as I cleaned out the gunk not long ago, you can see the thread and the tab see the picture below chain in the forground and on the right
9mm nut as per yam factory
« Reply #22 on: 30 January 2017, 06:36:03 am »
Cheers Sharpie,
Hold on a sec Tommy, it's Yamaha that created this problem in the the first place, nobody else!
So if you think that there's a reasonable chance that a nut isn't going to correctly tighten on to a thread the way it really should then you surely must understand peoples apprehension of the chance of over tightening and fecking things up even further, then opening up a world of pain.
The fact that if a 9mm wide nut officially needs 70Nm, it would seem perfectly plausible to me that a similar threaded nut but with a few more threads and made 3mm wider would only be a plus, even at the same torque?
So even though they've suggested 90Nm, i can't see a problem in tightening it just a bit more to 80Nm. It's still 10Nm more than before and with a wider area to lock down. Adding a bit of Loctite as suggested will obviously only help further, but in reality these are attempts at fixing a problem that Yamaha caused which really shouldn't exist, especially when it involves a moving and weight bearing part.
« Reply #23 on: 30 January 2017, 12:09:53 pm »
Quote
Yes that is a good point and I believe that the general consensus on here a while back was to go for the half way 80Nm with the wider nut.
tommyardin
« Reply #24 on: 30 January 2017, 01:37:00 pm »
Cheers Sharpie,
That's very true that this issues was caused by Yamaha in the first place.
Yamaha put their hands up to that fault and have replaced free of charge the 9 mm nut with a 12 mm nut when bikes went in for a service or maintenance and according to what I have heard repaired bikes that have been damaged by this faulty part. Now this process can only go on for a certain period as the last of these machines FZS600 were produced 14 years ago, the replacement parts are still available directly from Yamaha and i have been told if you make a fuss they will post the parts to you free of charge to just to keep the piece, to get you off their back.
So many vehicles get recalls on them because of faults and the manufactures for the best part do their level best to rectify the situation and that is exactly what Yamaha have done tried their best to rectify it buy producing a replacement part the 12 mm nut, and have given instructions on how to fit the part that their engineers have come up with.
So it would still seem to me to be folly to ignore their instructions as they will have spent a lot of time wanting to get it right as they could not afford for this to crop up again, and pick torque figures out of the sky is just folly
