Date: 27-03-26  Time: 17:16 pm
Author Topic: Trip meter woes  (Read 5984 times)
goldfazer
Trip meter woes
« on: 15 March 2012, 08:12:22 pm »
Trip counters and clock reset 'emselves when I turn the ignition off. Run when the bikes moving though. What's fallen orf?
(FZS600)
Davidjw
Re: Trip meter woes
« Reply #1 on: 15 March 2012, 08:47:48 pm »
when I had a similar issue to this turned out to be the battery on mine , got a new one and end of probs !
Fazbaz
Re: Trip meter woes
« Reply #2 on: 15 March 2012, 10:12:43 pm »
Presumably it starts off the button... that means the constant feed to the dash is interupted / cut any time the ignition is switched off... Fuse check then wiring check I'm afraid  :(
HTH.... Baz  :)
Gingernutz
Re: Trip meter woes
« Reply #3 on: 15 March 2012, 11:44:05 pm »
Thats a coincidence Colin has the same problem on his and has been trying to sort for a while. Best he can figure is that that the live wire into the odometer / trip is shorted or disconnected. Problem is we can't figure out what colour the wire is - anyone know?
Farjo
Re: Trip meter woes
« Reply #4 on: 16 March 2012, 06:27:55 am »
Have a look in the Downloads - bound to be a wiring diagram among them.
gassitt
Re: Trip meter woes
« Reply #5 on: 16 March 2012, 10:27:36 am »
When mine did this i found a break in a small  red/blue cable  in the loom near rear of battery
Robbie8666
Re: Trip meter woes
« Reply #6 on: 16 March 2012, 12:29:12 pm »
ok i felt daft asking this so kept sctum,
when my battery has a moment it resets the digital clock... i dont know how to reset the time....
must be simple but i just cant seem to do it!!
Andy Clap
Re: Trip meter woes
« Reply #7 on: 16 March 2012, 04:26:05 pm »
To set the clock:
  • Push both the SELECT and RESET buttons for at least 2 seconds
  • When hour digit starts flashing, push RESET button to set hours
  • Push SELECT to change to minutes
  • Push RESET to set minutes
  • Push SELECT to start the clock.
Gingernutz
Re: Trip meter woes
« Reply #8 on: 17 March 2012, 12:29:25 pm »
Robbie - I have had a fazer for years and when the clock goes back it takes me so long to remember how to fix it the clock is only right for a couple of months before it goes it other way
goldfazer
Re: Trip meter woes
« Reply #9 on: 17 March 2012, 12:33:18 pm »
Ah well, fuses (the 4/5 in the fuse box are all OK), can't see any others. Can't see a r/bu wire, but I ain't stripping anything out to look either :lol
So looks like it'll have to stay the way it is for the mo.
Robbie8666
Re: Trip meter woes
« Reply #10 on: 19 March 2012, 03:47:31 pm »
thanks for that Andy Clap I will print it off & stick it in my key case!
I know what you mean Gingernutz, most of the time it doesn't bother me but sometimes i need to know what time it is when riding to see if the chippy is still going to be open!!
