Date: 03-05-26  Time: 13:10 pm
Author Topic: clutch wrench...  (Read 6936 times)
Re: clutch wrench...
« Reply #25 on: 26 September 2016, 07:50:24 pm »
You shouldn't be using a torque wrench for removing nuts or bolts, it is not really designed for it. You could strain the inners.
anutz
« Reply #26 on: 26 September 2016, 08:25:30 pm »
yep i know, its an old one that i dont use to actually torque owt up with  :)
anutz
« Reply #27 on: 26 September 2016, 09:37:49 pm »
jobs done!!!
thanks for the input all - one of the trickier jobs i think.
Almost there now :)
anutz
« Reply #28 on: 26 September 2016, 09:39:20 pm »
oh as a tip anyone else do this and want to double check the clutch pull rod has engaged properly, just take the oil cap off and operate the clutch, its obvious...
Also to check the engagement before its all bolted up i.e. before you screw the case down once you think it has engaged, operate the pivot on the casing and it will pull the casing onto the engine casting....
both handy.
