Date: 24-04-26  Time: 14:55 pm
Author Topic: Light front end, slight knocking through the levers?  (Read 3271 times)
Tubz1983
« on: 24 August 2016, 07:47:18 pm »
As title states, the front end has got a bit light and flappy recently, and I can feel a little bit of knocking through the bars/levers at the final point of braking before a dead stop..... Head bearing? Sticking brake piston ? These are wild guesses hence the question !
Any thoughts ?!
slappy
Re: Light front end, slight knocking through the levers?
« Reply #1 on: 24 August 2016, 08:28:04 pm »
Head bearings.
Tubz1983
« Reply #2 on: 24 August 2016, 08:29:55 pm »
On the way out for sure then as I suspected, il book her in, thanks T
limax2
« Reply #3 on: 24 August 2016, 08:32:42 pm »
I agree, head bearings. But also check the wheel bearings for play.
« Reply #4 on: 24 August 2016, 08:34:31 pm »
Knocking on the head race could just be as simple as it needs tightening up a bit, or the head bearings are on their way out.
You should blatantly hear and feel that, it will be a proper jolt.
A similar but a bit more subtle reason could be brake pads moving in the caliper when braking, but if you're saying the steering feels light then it points to the head race area.
Bretty
« Reply #5 on: 24 August 2016, 10:36:23 pm »
I'm changing my head bearings this weekend.
I had a knock that has gotten progressively worse. It started out so slight the MOT tester fella couldn't work out if it was head beatings, forks or pads. So passed it because I don't think he wanted to go to all the trouble of finding out.
It might just need tightening, but I'm gonna do the change anyway as it's not been right for the last 6,000 miles.
« Reply #6 on: 25 August 2016, 06:29:37 am »
Friend of mine changed my bearings for me on my bike, i warn you now it ain't a pleasant job, especially removing the lower bearings if i remember correctly.  :smash
Bretty
« Reply #7 on: 25 August 2016, 12:34:04 pm »
The tricky bit is pulling the cups out and getting the bottom bearing off the head tube, right?
I bought a set of bearing pullers, is there much of a lip under the cups? Or do they just need a lot of force/whacking to get them out?
Nightfury
« Reply #8 on: 26 August 2016, 01:54:28 pm »
While you have the front up, check the fork bushes as well. Mine are worn and I get a knock as you say. Also the front feels a little light...
Tubz1983
« Reply #9 on: 26 August 2016, 09:38:20 pm »
Thanks again guys, I shall inspect. T
« Reply #10 on: 26 August 2016, 10:03:37 pm »
I remember copious amounts of whacking and maybe even a bit of heat treatment.
Bretty
« Reply #11 on: 26 August 2016, 10:14:52 pm »
Cheers Darrsi! I'm guessing you're talking about the bearing on the head tube. I'll dig out the blowtorch and make sure I have the dremel to hand.
Planning an early start tomorrow to crack on with it. I've just done oil and seal change on the forks which was fairly painless. :)
celticdog
« Reply #12 on: 27 August 2016, 12:01:35 am »
I had the same symptoms, it turned out to be the wheel bearings in my case, worth checking.  :)
« Reply #13 on: 27 August 2016, 12:28:25 am »
From experience wheel bearings squeal, that's how i've always known they're on their way out.
And yeah, the lower bearing takes all the weight of breaking so has a habit of planting itself firmly in place over time.
BBROWN1664
« Reply #14 on: 27 August 2016, 09:25:31 am »
You can also get a slight clicking from the brake pad/brake disk which you notice more on light braking as you come to a complete stop. You don't notice it as much under heavy braking or at higher speeds.
You do need very sensitive ears/fingers to notice this though.
