Date: 02-05-26  Time: 07:24 am
Author Topic: rear shock advice please fazer 600 2002  (Read 22513 times)
andy352299
Re: rear shock advice please fazer 600 2002
« Reply #25 on: 21 March 2012, 01:11:18 pm »
254-255 is the same as the fazer as far as i can tell without removing the swinging arm, i will check the length later
andy352299
« Reply #26 on: 21 March 2012, 05:43:10 pm »
centre of fazer swinging arm pivot to centre of wheel spindle slot 540mm
kebab19
« Reply #27 on: 21 March 2012, 06:29:43 pm »
Hmm, bit disappointing, hoped it woulda been the same  :\ .
If the wheelbase was 15-20mm shorter would it be too radical? Prob'ly wheelie like a turbo hayabusa
How much does a chain stretch over its lifespan anyway?
andy352299
« Reply #28 on: 04 April 2012, 10:26:30 pm »
a bit of an update,
i have had the original shock rebuild by a chap called Hans who was recommended to me by Fazbaz,
it took two weeks in total from the time i took it to the post office until i got it back and refitted it.so i cannot complain about that. £70 inc p&p i could have had the spring powder coated any colour i liked for an extra £10 but i did not think it needed it
so the main thing is does it work?
1st impression after a 10 minute ride is yes,   tommorrow i plan to have a ride to a couple of places that have some large dips in the road and see how it feels then.
After that the next plan is to service the forks
His Dudeness
« Reply #29 on: 04 April 2012, 11:07:06 pm »
what does a rebuild involve?
kebab19
« Reply #30 on: 05 April 2012, 10:49:36 am »
Drilling a hole into the top of the shock body and emptying out existing oil.
Welding a schrader valve onto the area that was drilled.
Pressurising the shock through the schrader valve - not sure if it's done through oil only or with gas too.
Eventually the shock will go off but because of the valve it can easily be re-done again and again, in effect allowing a non-rebuildable shock to be used repeatedly.
A very practical and cost effective solution; my only concern would be the legality from an insurance point of view in the event of a payout? F***ers would probably try & weasel out because of 'modified / non-standard suspension parts'.....
JoshVaughan
« Reply #31 on: 20 April 2013, 05:32:18 pm »
is it possible to put a 2000 model r6 swing arm onto a 2001 fzs 600 fazer?
