Date: 09-05-26  Time: 02:31 am
Author Topic: stuttering fzs 600  (Read 389574 times)
Re: stuttering fzs 600
« Reply #500 on: 26 August 2012, 09:14:16 am »
working yesterday but found some fettling time in the garage :D .....cleaned up the block and fitted gasket , head and torqued in two stages too 35 nm  ;) ...day off today with a few jobs to do around the house :\  but will try to sneak out to the garage to fit the cams ;)
« Reply #501 on: 26 August 2012, 04:38:11 pm »
bit more work on the fazer today  :D  fitted the cams and set the timing refitted the cam cover and also the geni cover  :) ......starting to look like a complete bike now    ;)
CRH
« Reply #502 on: 26 August 2012, 09:08:24 pm »
not long now then matey? ;) .......got a good feeling bt this one?..not long now before we hit that ...RED"..line!!!!!!!!! 8)
« Reply #503 on: 26 August 2012, 09:15:14 pm »
very good crh  :rollin  carbs on next after ive adjusted the mixture  ;) and then all the bits and pieces  :)
just been reading the darrsi post.........thats been in the back of my mind from day one as replaced the filter shortly before i noticed the stutter  :rolleyes
CRH
« Reply #504 on: 26 August 2012, 09:18:09 pm »
yes that was mentioned wasn,t it?...something about having a air tight seal around it to wasn,t it?..... :rolleyes
« Reply #505 on: 26 August 2012, 09:24:21 pm »
thats right.....i have a pattern filter in there at moment looks as good as original,fits well  :D ....iam thinking of treating it to a k+n,but a few more things to check before i do that  ;)
CRH
« Reply #506 on: 26 August 2012, 09:29:58 pm »
well,ive got a KnN in mine and it sounds lush when you give it some!!...lovely induction roar, accompanied by a harpoon race can!!..so i would recomend you get one?.... ;)
« Reply #507 on: 27 August 2012, 08:27:33 am »
ok thats recomended by DARSSI and CRH  ;) [size=78%]...... i`ll get the bike back together and treat it to a k+n filter [/size] :D
« Reply #508 on: 27 August 2012, 10:46:29 am »
more garage time this morning.......carbs,checked the mixture.......4 turns out  :eek .....as ive stated before i`ve owned the bike for 10 yrs,9000 miles when bought now on 40000,carbs not been touched in my ownership and main dealer service records before that  :\
 standard mixture settings should be 2 turns out  :eek i was going to richen by 1/2 turn,but left as is and re-fitted  ;)
1 1/12 hrs this morning,struggled re-fitting the carbs this time  :\ ....untill i realised its a lot easier mounting onto the air box rubbers and securing with the julibee clips and then sliding into cylinder head rubbers  ;) ..........i know that already,senior moment as iam at that funny age  ;)
« Reply #509 on: 27 August 2012, 10:49:37 am »
forgot to mention time taken on this post.....took my time getting the timing right,turned over on the crank and  re-checked a few times........3 1/4 hours  :)
CRH
« Reply #510 on: 27 August 2012, 11:54:43 am »
yes red!...you still got approx 2 1/2hrs left!! ;) .....4 turns out you say?....shit!!! thats alot int it?...chkd mine the other day and mine where ...cyl,s 1 plus 4...2 1/2 turns out...and 2plus 3 ...2 3/4 turns out...so i tweaked em bk to 2 1/2 ...and it defo made motor smoother on idle!! ...what you been getting mpg wise then?....i average 52 taking it easy :rolleyes .....worst i got was 40.. ps you changing oil and filter b4 you crack her up??....allways wise i recon cus of bits  left behind you dont allways see ;) ;) .....best being safe than sorry!!!!!
« Reply #511 on: 27 August 2012, 02:38:09 pm »
4 turns was a bit of a surprise  :eek ..............59 mpg before strip down  :) no problems there  :D
« Reply #512 on: 27 August 2012, 02:40:45 pm »
another 1 1/2 hours to add to the total,just fitted all the bits and pieces all i need to do now is top up the coolant level....job done
oh...............forgot to mention............brum,brum,brrrrrrrrrrrrrrrrrrrrrrruuuuummmmmmmmmmmmmmm  :D [size=78%] [/size]
CRH
« Reply #513 on: 27 August 2012, 02:45:20 pm »
What?..it runs??????? :b .......looks like a trip out then this afto?? ;) ........
CRH
« Reply #514 on: 27 August 2012, 02:57:03 pm »
1 hour remaining ?....just time to rip off ya dustbin lid n make yaself a big fat medal t hang round ya neck me thinks!!!!!!! :b ....got a good feeling bt this one? ;)
Dead Eye
« Reply #515 on: 27 August 2012, 03:22:13 pm »
Definitely recommend the K&N as well ;) Got one on mine but having replaced the entire exhaust system at the same time I can't comment exactly on it precisely - the entire system has been running like a dream though. Can't wait to get mine back tomorrow :D
« Reply #516 on: 27 August 2012, 03:27:28 pm »
I've got replaced stainless down pipes and a what's virtually a race can, and it's always been just fine, but the K&N has made it noticeably better  :b  (not including the latest hiccup obviously)
Sounds a tiny bit different as well.
« Reply #517 on: 27 August 2012, 08:21:25 pm »
had an afternoon with mumsy today  as 80th birthday,good day  :D ,quized her and her elderly friends on the stutter problem and all i got was blank looks  :rolleyes ........bike fired up a treat this morning no problem.....inlet shims were fine,exhaust i increased by 1 size (0.05 mm) did`nt think i would notice the difference,could not have been more wrong........top end is as quite as something very quite  ;) .....not a single rattle or knock,even on first start up  :D  well pleased with that  8)  tick over is a bit lumpy now so will re-balance the carbs...need to do a bit of homework on this to understand ....HG  :o .......as dont know what this is yet....but i do know its quite crucial to getting the best from the bike  :D
    anyone know about this HG thing ?.......................... ;)
« Reply #518 on: 27 August 2012, 08:33:31 pm »
cheers matey  :)  shame i have a plastic bin,but will wear it anyway  :D ....need to get some coolant and balance the carbs and then it will be test ride time  ;)
CRH
« Reply #519 on: 27 August 2012, 08:43:57 pm »
dont understand this HG meself red?...but think its something to do with pull of vacuum!!..ie, a maximum and minimum between cylinders?.... ;)
« Reply #520 on: 27 August 2012, 08:51:13 pm »
yes mate .....its got to be something like that  ;) .........just waiting for someone to come along and enlighten me  ;) ;)
Andy FZS
« Reply #521 on: 27 August 2012, 08:53:08 pm »
The determination of a gas pressure that is less in magnitude than the pressure of the atmosphere. This low pressure can be expressed in terms of the height in millimeters of a column of mercury which the given pressure (vacuum) will support, referenced to zero pressure. The height of the column of mercury which the pressure will support may also be expressed in micrometers. The unit most commonly used is the torr, equal to 1 mm (0.03937 in.) of mercury (mmHg).
Pinched this off the net I think it explains............... :D
Andy
CRH
« Reply #522 on: 27 August 2012, 08:57:28 pm »
that is exactly what i was trying to say andy? :rolleyes :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin
Andy FZS
« Reply #523 on: 27 August 2012, 09:03:29 pm »
I was just agreeing with you :lol
Andy
CRH
« Reply #524 on: 27 August 2012, 09:05:52 pm »
well thats fkd it then....looks like we both wrong!!!!!!!!!!,,,,,soz red!! :lol :lol :lol
