Date: 09-05-26  Time: 02:31 am
Author Topic: stuttering fzs 600  (Read 389574 times)
CRH
Re: stuttering fzs 600
« Reply #175 on: 22 May 2012, 10:12:56 pm »
how the fk do they shit?????????????? :\
ade the blade
« Reply #176 on: 22 May 2012, 10:19:42 pm »
night night !! ;)
CRH
« Reply #177 on: 22 May 2012, 10:30:50 pm »
you did not answer my question?? :lol
CRH
« Reply #178 on: 23 May 2012, 08:56:45 pm »
hi, red, how did the test ride go???
« Reply #179 on: 23 May 2012, 08:57:24 pm »
ok....more sensable stuff.....took the bike to work today..after replacing the diaphrams last night......made no difference  :\ ......got in tonight and fitted the downpipes i bought off DEADEYE,I`ve welded the old ones a few times now over the years and was thinking that some of the weld might be causing a restriction,i`ve also replaced the can with one thats been in the garage for years,when i took the old one off there was quite a lot of what i guess to be loose/broken baffles shook the can and got most of them out but had the spare so on it went...will use for work again tommrow.............hows the decking going ade ?
« Reply #180 on: 23 May 2012, 08:58:42 pm »
sorry crh....think we posted at the same time.....not good,please see below  ;)
CRH
« Reply #181 on: 23 May 2012, 09:15:38 pm »
ok. thats me relagated then?? :\ .....thort we was on to something with the diaphrams?...right ? this may or mabe not? ...but i recently swapped my end can from std to a harpoon carbon oval!!!, now although the sound it made was very impresive? on the road it wasnt so good?....low revs fine!!...but just couldnt get it to rev above 7500 without it holding back? as if i wasnt getting any fuel?...so just to double check? ..i reverted bk to std and it was perfect? only took it to 11000 but that was good enuf for me!!so i thort to myself ime not going to lett it beat me ,i loved the sound of the harpoon so much?.... so i decided to make a baffle for it!!,just to see if a littie bit of back pressure would help??...and guess what?....bingo!! nows revs has it should and goes like a rocket??? ;) ....so ?
« Reply #182 on: 23 May 2012, 09:27:48 pm »
thats interesting  ;) ......see what happens tommrow.......iam running out of ideas now,will try ade tip about the sliders and then re-check everything ive done so far.....thanks for you help on this one  :)
« Reply #183 on: 23 May 2012, 09:36:31 pm »
might check the carbs balance again seeing as ive changed the diaphrams  ;)
CRH
« Reply #184 on: 23 May 2012, 09:39:19 pm »
thats ok! sorry havnt been any help so far?.....its getting to me as well?...dont you just hate it ,when you think you.v don everything?..and it still no good!!!.....i was just like you with my f1 honda that time?...thats why i was sure i was on to sumat with the diaphrams???....
« Reply #185 on: 23 May 2012, 09:53:19 pm »
iam sure its something simple and something i`ve already looked at...i just cant see anything wrong.....the test rides ive been doing have been on the motorway (when its quite ) and i now have a square rear tyre,its getting low anyway so will be buying some new tyres this weekend.....seams strange buying new tyres when the things not running right but iam not going to give up  :\
CRH
« Reply #186 on: 23 May 2012, 10:06:10 pm »
no mate!! dont blame you!... you watch? itl be sumat so simple i bet?.....just put it down to a......phazer"" in your life of which ime sure you will overcome!!!!!......
CRH
« Reply #187 on: 23 May 2012, 10:24:48 pm »
ru going for maxiss then?
Dead Eye
« Reply #188 on: 23 May 2012, 11:48:11 pm »
Keep going red, we've all come too far for it to end without resolution :P
« Reply #189 on: 24 May 2012, 06:25:09 am »
yes  i think i might, my friends has them on a xj6 and is happy with them...£137 from busters for pr + p&p seams like a good deal  :D
« Reply #190 on: 24 May 2012, 06:27:30 am »
cheers matey.......think ill re-read my own topic and see if i can make sense of it...the answer is in here somewhere iam sure.... ;)
« Reply #191 on: 24 May 2012, 08:54:40 pm »
used bike for work today after fitting new down tubes and can.....no change  :\ .....looks like carbs off again,not too sure what iam going to do with them though :rolleyes
CRH
« Reply #192 on: 24 May 2012, 09:30:38 pm »
would it  be worthwhile sorting a set of carbs complete with tps off net? possibly off a lower mileage bike?...or even someone like hills motorcycle salvage?....had loads of stuff of them?...breaking hundreds of bikes weekly!!....not bad on prices either?
« Reply #193 on: 25 May 2012, 06:32:49 am »
 :o :o :o   ah yes......i made a big mistake there  :o :o :o .....with the seconhand carbs i bought to try and trace the problem,i should have fitted them straight to the bike instead of removing the diaphram covers and float bowls for inspection and then breaking the petrol supply t-peice which made the carbs un-useable..hence  swapping the internals over,i might have a problem with the carb boddies !!,supprised no ones said anything yet,you must be all to polite :D ......i might source another set of carbs and try again,seen a cheap set on ebay close to home and i can always re-sell afterwards
 not used hills before,where are they based....off to hemel hempstead today,40mile round trip which will give me plenty of time to test the bike and try and work out whats going on  ;)
CRH
« Reply #194 on: 25 May 2012, 08:57:51 am »
hi red,..its called...hills salvage recycling ltd,..gerrard place,..east gillibrands,..skelmersdale,..lancs,..wn8 9su....01695 455777..............................www.hills-motors.co.uk....also?...motorcycle recycle! think they based in chester?...01206 793111...they also good on prices!!!..good luck! clive.
« Reply #195 on: 25 May 2012, 07:26:46 pm »
thanks for that clive  :) used the bike for work today,approx 50 miles round trip and the bike seams to be getting better,if i ease the throttle open instead of snapping it open the stutter is not there  :) ...its only when i realy hammer it  that it starts playing up...i think i`ll use it for a while and see what happens,its been a long winter and its just been sat in the garage so parhaps it just needs to be used  ;)
CRH
« Reply #196 on: 25 May 2012, 07:37:29 pm »
not been using mine either?....taxin it next wk!..so hopefully get few miles racked up?...does em no favours standing? just hope it clears itself hey?? ;) ....
« Reply #197 on: 25 May 2012, 07:49:04 pm »
hope so...iam going to have fun trying  ;) ;) ;) ...going to order tyres tommrow as old ones spoiling the ride.they have a mind of there own  :eek
« Reply #198 on: 27 May 2012, 08:54:05 pm »
up early this morning,no work so off on the bike,out on the a40 to oxford and on towards whitney ,pull over at hein gerreck (not spelt like that but you know what i mean)closed but had tea in car park,tea break over and down to goring on thames and then pangbourne quick stop and a stretch and then onto reading,henley.marlow and home to high wycombe....thats what i call a sunday morning  :D ....bike is running better but not perfect,if i ease the throttle open keeping up with engine speed i can aviod the 5000 stutter.its only when i give it full throttle and let the engine catch up that i get the stutter....going to use it for work all this week and clock up a few miles and see if it helps.....managed to round off the square rear tyre  ;) ;) ;) ...forgot to order the new ones  :o
CRH
« Reply #199 on: 27 May 2012, 09:02:55 pm »
are you using a std can? or like ade u got a fruity fitted?? ...i ask this cus you too might need a rejet??????? :rolleyes
