Date: 09-05-26  Time: 02:31 am
Author Topic: stuttering fzs 600  (Read 389591 times)
ade the blade
Re: stuttering fzs 600
« Reply #100 on: 29 April 2012, 03:08:49 pm »
thanks ade...just what i need....a kick up the backside...........my wifes fed up with flushing the loo with a bucket and bathing in the front room using my grandads old tin bath.......good for me though as nothing worth watching on the telly  ;) ;) ;) ;)
if she farts, run like hell as you could have your own personal tsunami !! :lol :lol :lol
« Reply #101 on: 30 April 2012, 06:19:59 am »
ade....you`ve met my wife then  ;) ;) ;)
ade the blade
« Reply #102 on: 30 April 2012, 09:43:39 am »
no, but i know the difference between distant thunder and a galvanised fart !! :lol :lol
« Reply #103 on: 30 April 2012, 07:42:36 pm »
ade ,god help you if my wife reads this post.....made me laugh though  :rollin :rollin :rollin :rollin
« Reply #104 on: 30 April 2012, 07:54:01 pm »
ok...enough of this farting about....had a bit of a balls up today....went straight out to the garage tonight and removed the carbs from the fazer,35 mins from start to finish,put the two next to each other and compared the sliders,not much between them so i thought i would swap the pipes in readyness to fit the new carbs tommrow night all went well untill i noticed the fuel supply pipe was in the wrong position and needed twisting round a bit so i released the clip and turned it with my hand......thats when the t peice broke  :eek .   to replace this means separating the carbs and iam not doing that so the only option i have is to swap all the internals,sliders,needles,jets and emulsion tubes,i`ll keep the origanal diaphrams as they look better than the new ones.unless i can fine some cheap pattern ones...........oh the joys of fazer ownership  :(
 on the up side the new carbs were well pitted and had seen a fair few winters mine are bright and clean as iam a pansy and dont ride in the winter
ade the blade
« Reply #105 on: 30 April 2012, 08:17:43 pm »
 :rolleyes :rolleyes :rolleyes :rolleyes always one, ya bozo. only kidding. good luck with the innards. hey,would sliders etc be classed as carb offal like chitterlings and tripe ? :lol :lol
« Reply #106 on: 30 April 2012, 08:23:02 pm »
just did`nt want you to come to any harm,you`ve been a helpful chap and the wife`s a big unit......i mean a delicate little thing...... :D
« Reply #107 on: 06 May 2012, 06:25:39 pm »
at last a bit more work on my fazer...today i stripped the secondhand carbs and fitted the sliders,needles, main and pilot jets,used my diaphrams as they look good and the seconhand ones were a bit mis-shaped and not as flexable as mine,slid the carbs back into position and tightened up the clips around the inlet rubbers,thats when i sheered one of the bolts,not going mad the heads in excellent condition not chewed at all,sheered just below the head of the screw (metal fatiuge ?) m4 x25mm,could not find any in my parts bins so will see what b&q have in the morning,probably best to replace all 8.....update tommrow :)
« Reply #108 on: 07 May 2012, 08:22:18 pm »
got the screws from b and q this morning,£3.57 for ten,could only get slotted so replaced just the one for now,air box bolted back in place and battery re-fitted.pressed the start button and a few seconds later the bikes running again,i swapped over the tps as well so i adjusted that so it read 5000 rpm on the rev counter,connected up the gauges to balance the carbs,not to far out but runs a lot better now they are spot on,hard to get to the adjustment screws but with a long slim posi screwdriver and a torch the job went well,well worth doing...i need to fit the stainless downpipes i bought off DEADEYE but i want to clean them up a bit first, iam going to use autosol and some fine wet and dry, need to buy these as right out at the moment so test ride will be next weekend now,it starts better now hardly turning over and has better pick-up  ;)
andy f
« Reply #109 on: 08 May 2012, 10:59:59 am »
Hey, I had the same sort of thing a few months back, I dicked about with loads of things and the one day I replaced the air filter ( which wasn't that old, hence I hadn't changed it earlier ) but also I looked at this bit
http://foc-u.co.uk/index.php/topic,2849.0.html
Item 24, mine was blocked . Cleaned the tubes out etc and it was sorted.
Now it may have been just down to the air filter needing replacement and the other bit had jack **** to do with it but maybe worth a look it's a 5 min job !
Andy
« Reply #110 on: 08 May 2012, 07:22:25 pm »
hi andy,i did see that post and thought about it and then forgot about it.the air filter would have to be in a right old state to cause a stutter and i like you have a new one,so parhaps you might have stumbled accross something here,iam off to the garage now to check my tubes.....i`ll look at the bike while iam out there too  :rollin :rollin :rollin .....
 will let you know shortly ;)
« Reply #111 on: 09 May 2012, 06:29:34 am »
breather tubes checked last night,no problems there.....there was a post on here a while back,a chap had replaced his air filter only to have a stutter when test riding changed the filter back and all was ok its been playing on my mind for a while but cant see how it would cause a stutter...and now theres two of you !!!!!
ade the blade
« Reply #112 on: 09 May 2012, 05:34:56 pm »
no, i don`t believe air filter should even be considered as the prob. gotta go down the ignition / fuel routes. ;)
« Reply #113 on: 09 May 2012, 08:23:24 pm »
bike starts and runs better now and pick-up is better,not been for a test ride yet (bloody rain)....if the carb rebuild has not solved the problem i`ll change the ecu next  ;)
« Reply #114 on: 13 May 2012, 12:55:15 pm »
test ride this morning  :( :( :( :( :( ......i`ll change the ecu next............
ade the blade
« Reply #115 on: 13 May 2012, 02:00:01 pm »
never mind mate.......did carbs make any difference for you ?
« Reply #116 on: 13 May 2012, 05:56:08 pm »
yes...balancing the carbs was well worth it....better pick-up from tick-over and smoother running
ive changed the ecu this afternoon simple job,unbolt the tail piece,remove tools,unbolt rear light,unscrew ecu,disconnect 2 block connectors....re-fitting is a reversal of removing....as they say in all good manuals  :D
not test ridden yet but starts and runs ok,will use it for work in the morning  ;)
« Reply #117 on: 14 May 2012, 07:47:49 pm »
more rain.....no test ride....iam going to bypass the fuel filter just so i can cross that off the list aswell....probably be the weekend before i get a test ride now  :(
« Reply #118 on: 16 May 2012, 09:19:51 pm »
removed the fuel filter tonight and put a straight piece of tube in its place....noticed that there was too much play in the throttle and saw that the bottom lock nut on one of the throttle cables had come off and was resting on the bottom of the cable  :\ :\ ....90 mins later managed to get it back on and tight without removing the carbs again  :) .............test ride at weekend  ;)
« Reply #119 on: 21 May 2012, 07:13:01 pm »
working all weekend so no time for a test ride....so took it to work today...no change  :\ ...so tonight when i got in i put the origanal ecu back on and removed the straight tube and re-fitted the fuel filter.....i looked at the diaphrams on the replacement carbs which i thought were a bit stiff,thats the reason for not fitting them,but after a quick soak in some petrol they have loosened up a bit and returned to the correct shape,iam going to leave them to soak overnight and fit them tommrow,all being well...had a quick look at the bike and theres just enough room to replace them without removing the carbs again  :)
CRH
« Reply #120 on: 21 May 2012, 07:20:18 pm »
fingers crossed then red?? .....doesnt look like ade got round to trying his either?..wouldnt leave them soaking in petrol all night though??might fk em up?? :'( clive.
« Reply #121 on: 21 May 2012, 07:41:08 pm »
yes i was thinking that as well....just waiting for someone to comfirm...thank you,now removed from petrol bath....yes ade`s gone a bit quite......sounds like hes got a low flow rate....no doubt a bit embarrased to talk about it on here  :rollin :rollin :rollin
ade the blade
« Reply #122 on: 21 May 2012, 08:12:39 pm »
booooooooooooooooooooooooooooooooooooooo !!! caught you :lol  well here i am once again. freshly scrubbed arse and raring to go...........ooooeeeeerrrr missus. well, firstly many many thanks to everyone who participated and voted :rolleyes  in my `count to 5` experiment. the end result.........................................................................thats right, none the bloody wiser :lol :lol :lol :lol :lol . no, in all honesty, i am more than convinced now that my pump is sh&gged, so a little peek at fleabay is on the cards methinks.
« Reply #123 on: 21 May 2012, 08:20:29 pm »
ahhhhhhh........just as you thought it was safe ...............he`s back....... :rollin :rollin :rollin ...loads of cheap pumps on fleabay...good luck matey  :)
CRH
« Reply #124 on: 21 May 2012, 08:28:51 pm »
looks like the.....blade" saw  red"..with that comment??....yea? crap i know?? :o
